thinking of putting a small pulley above my lathe for bigger logs. Just severely squished my fingers trying to hold a log in a chuck and push in the tailstock..
any advice or photos? my ceiling is a metal framed building, but i have plywood as ceiling material. Probably wait till it cools off before venturing into my attic, but i think there are some 2x4s that are holding up the plywood...
What ever is up there, be sure to spread your load across at least 4 structural members. I would use a 2x8 on edge and put the pulley anchor point at the center.
I once saw an A frame set up on rollers that I thought was wonderful. It had a chain hoist. You could simply lift the log, roll it over the lathe and load it up. Storage might be a problem but if you have room that's a great concept.
Darrin, I attached a 2x4 above the center line of my lathe and then bolted on a track for a sliding barn door. I attached the wheels to a small electric hoist and I was good to go. It works great for removing the tailstock.
Surprisingly, if you do the beam deflection calculations you will find that the 2x8 (approx 1.5x7.5 actual) is about 9% stronger than the 4x6 (approx 3.5x5.5 actual). However the latter would give 2 inches more head room if placed below the ceiling. As a practical matter, even a 2x6 laid across joists on 24-inch centers should support much more load than you can lift with a simple pulley. I would put the cross piece on top of the joists and drop a 5/8" or larger all-thread rod through the ceiling to carry the load. A long u-bolt upside down over the cross piece attached to small steel plate bored to take the u-bolt ends and the all-thread can be used to make the connection.
Joe has the right idea. You need a track or rail to move the hoist up and down the bed. It will never balance from one hook on the ceiling. I use an engine hoist but I have a big shop.
I have an engine lifter that I not only use to lift my lathe onto the trailer (a 1000 stuby )
But use to lift in bigger blocks
I brought one of these years ago for a engineering business I owned cost me thousands.
The one I have now lifts 1.5 tonne and cost me $250
I can also get on my trailer by myself then use to off load things the other end.Or pick up trunks.
Only thing against it is I have to have a big clean up each time in my workshop when I use it
Having a fixed point above the lathe is not user friendly and has its limitations . A mate has a slide rail that a chain block slides on
but he tends to borrow my lifer as its
more versatile.I can back the trailer right up to my shop pick up a block and take it to the lathe.
When I have a woodturning event on I take in then lifter and eveyone unloads their lathes with it. The wide foot prind means you can pick up my stubby and move it all around the building
