Re: Vessel Support
John Smith
I do not own one, but I have turned with one. The rest is very versatile. The wheels can be positioned almost anywhere you want them around the the ring. You can also add more wheels if you want. In bowl rest mode you can position the wheels on the front side if you want. That is where i would put them.
Another advantage is you can take a section out to install it. So after turning the outside of your vessel, you can install the steady while leaving the tailstock to support the end. eEasier to get everything centered.
The base is made with 2 moveable cleats for between the ways. I think it will fit the bed gap on any lathe. No need to buy an adapter or anything when you upgrade to your next lathe.
If I had not just built one, I would buy one of these in a heartbeat.
John
