After seeing a demo by Doug Fisher, I wanted to give his vacuum chucking system a try. I'm no Doug Fisher, but really had some fun with this. It's 11.5" x 1" thick. Finished with Tung Oil and buffed. A fellow woodturner bought this before the finish was on so I hope he likes it even better now.
Thanks for looking and all comments are more than welcome.
That's very nice. I like the decoration you've added to the rim. I think it enhances, rather than competes with or covers up, the beauty of the wood. Very well done.
That is a beautiful piece........fit for display in any setting! Did you use a multi-axis hold to do the rings on the rim? Super color and the texturing is tasteful, not overdone.
Maybe calling it "Doug's System" was a bad choice of words. Basically it's a good ole vacuum chuck that holds the bottom of the piece while designing the front. Because the back of the piece is rounded, you can move it all over the place in the vacuum chuck and not only get offset shapes, but the depth angles will vary as well. A ton of fun to play with!
