I am in the process of making some bottle stoppers. Some of the wood I will be turning is quite hard. If I apply some parafin to the threads of the bottlestopper insert will it cause problems with the CA glue getting a good bond when I apply it inside the drill hole?
Hi Dale! I use wax on all my bottle stopper threads and the CA has always held up fine. I use two of them for myself every day (though not for wine) and they hold just fine even though I have a tendency to twist them as I remove the stopper. Others might know the chemical properties of such a situation, but I'm just going by what has worked for me.
I'm glad Don answered. I would have said no based on the fact that I often use floor wax as a release agent when I Glue things and don't want the glue to stick. I've put the wax on wood and then CA'd a joint and then peeled the CA off the wood where the wax was. Maybe Johnson's paste wax has something more in it than whatever wax he is using for his stoppers.
I think the reason it works OK for me is I just run a candle, or whatever hard wax I have on hand over the threads once and that's it. It might be just enough to lubricate the threads, yet let enough glue through to hold the stopper together. Just a guess, John has been doing this way longer than I have.
I tried applying the parafin to the threads of the stopper but the suggested drill diameter was apparently too small. So about of 1/4 of the way in the stopper stopped dead. Tried to back it out and the threads that join to the stopper bottom started to loosen. Caught between two no go's I had to punt.
The next attempt I used a bit a smidge larger than recommended and used thick CA glue on the threads. Was able to get a bite on the wood and the stopper seated perfectly and from what I can see is secure. Probably could have stuck with the wax technique if the stopper was one piece but that is not the case. Thanks for your inputs.
I too had a problem at first with the self-tapping inserts, but chose a different solution. I tap the hole with a standard tap and tap wrench first. It takes only a moment and saves fighting with the insert.
