Some days you are the fly, some days you are the
Steven Antonucci
windshield.
I posted this vessel earlier when the tenon failed, and I had to reattach it and encapsulate it in the maple waste block.
After retruing it, I went back to hollowing it. With Alan Stratton's peach crotch video fresh in my memory, I slowed the lathe down to a painful pace (480RPM) and went back to open the inside out. As you can see, this redwood was a few voids in it.
Other side:
Things were moving along when there was a loud "pop" (lathe spinning, but not in a cut... just a pop!)
Cracked from the undercut of the shoulder clear to the mouth opening. Bad words were said...
It is now when my brain started thinking about stupid things it could do to make things worse. "Hey, Steve... you should push that bark inclusion through and take it out the top...", it whispered.
Pushing it in was easy. Getting the knot out was not. I twisted and contorted that %$$^ thing every way possible, and it wouldn't come out. If you look closely, you'll see that there is a black outline. This tree was through a fire, which is important to the redwood for germinating seeds and clearing the undergrowth... because redwoods are really fire resistant! So this tree burned just enough that I could reach in with pliers and break the weakened inclusion into smaller pieces.
Success!
With the knot removed, I put some glue in the crack:
A wet paper towel cleans up the squeeze out. Hoping to finish the undercut this weekend. One lower speed available(216RPM... I might as well chew it out...).
I hand sand everything when they come off the lathe anyhow, so if I can get it finish hollowed, I might just get this vessel completed.
Thanks for checking in.
Steve
