Round, brown & rusty
Leo Cuellar
Haven't been on the lathe too much lately, but wanted to share one that didn't turn out too bad. This is Cherry about 6" in diameter. I used a round burner tip for texturing on the band. I had to dust off the carving tools and hack out the simulated rivets. I used Modern Masters Iron covered with Krylon clear coat which turned the rust bluish... fortunately shellac over that brought back some of the red tone. Then several coats of Watco semi-gloss lacquer.
I was finally able to track down some of the MM clear seal coat for their effects, so I'm going to do another one of these. Next one will have the band a little lower down the bowl with a full bead on each side of the band. This one looks a little "off"
As you are all aware, my camera isn't stellar, but I took these pictures in natural light outside the shop. Haven't had time to go look for something to diffuse the shop lighting.
Now I've got to run to the lumber yard & get a few 2 x 4's to build a shack for the compressor I'll be getting next week
Have fun everyone!!!
