bandsaw blade snapped
Starry Chan
I had two highland woodturner's bandsaw blades snapped after using it for sometime.
I think the first one snapped possible because of over tensioning. That blade was also getting dull so it snapped when it caught something hard. The second blade snapped this afternoon. This blade is still sharp. I did notice a slight fluttering so the blade may be under tensioned. However, it cut three blanks with no problem before it snapped. This one snapped at the joint. I can tell it is the joint as it is in a different color. The blade track properly in the center of the wheel.
Does bandsaw blade snap when it fell off the wheel or it just happened because of metal fatique or other reason? What is the best way to prevent this from happening? Also, I have the habit of detensioning the blade after each session. I am wondering whether this actually weaken the blade.
I would appreciate your sharing of your experience.
Re: bandsaw blade snapped
robo hippy
If it broke at the weld, bad weld. If not, a number of things. One, DO NOT cut with a dull blade. Just too dangerous. I had 4 stitches once, "I can get one more cut out of it....." If you are in the habit of having the upper blade guide high, that puts stress on the blade, and it breaks from the back side towards the teeth. This will make it flutter in a front to back way. Usually if there is one crack, there are more. If the thrust bearing is not right up against the back of the blade, both top and bottom, the same thing can happen. This is some thing that needs to be checked regularly as they seem to want to work loose. Other than that, don't know, but any time you have to force the wood you are stressing the blade.
robo hippy
bob davis
i had many problems with a highland blade.ifrst one broke .second welded improperly..same third one. shipped all thre back toshow poor quality. never received refund
I had terrible problems with them bending at the slightest catch. I won't buy anymore. My $6 blades that I buy here don't cut as clean but I seldom bend one when cutting green wood and have only had one break and I've gone through probably a dozen in the last bunch of years.
Starry Chan
I called Highland this morning. They asked me to send the snapped one back for evaluation.
I think I will take your advice to buy bandsaw blades for cutting green wood at local saw sharpening shops. Their selections will probably be limited. However, it looks like I can get one for about $18 plus sales tax instead of paying $23 to $25 plus S&H for a Highland or Timberwolf one. I will check them next Monday.
Starry
Dale Bonertz
Starry,
You might try bandsawblades.com (I'm pretty sure that's it). I have been using them for years. Good prices and decent blades. Just a thought if your looking for a new supplier.
Dale
Lewis Dodd
I like the Olson Pro from various sources, (Rockler)
Fred Holder
I've been using bandsaws for about 20 years and have never had a blade break. I've been using Timberwolf blades almost exclusively. When they get dull, I replace them with a new one. I've had one or two seized by wet wood and the blade bent, but didn't break. Of course, it might as well have broken, because I had to break it to get the wood off the blade.
I also use Carter guides, which may help support the blade. Also, I don't follow the instructions in many of the books, which say to loosen the blade when through using it. I never loosen my blade except to replace it or readjust it.
Cheap blades is not the way to go in my opinion. Timberwolf blades stand up well and perform well.
fred, i agree
Re: bandsaw blade snapped *LINK*
Peter Hyde
Spence Distributors was mentioned on this forum several years ago and I have to say they have served me well. Mix and match any size/tpi to get quantity discounts. Service is impeccable and the price quoted is the price to your door. I use the flexback blades and they are good all round blades.
http://www.spencedistributors.com/index.cfm
