200+ woodworking book reviews
Bearing Bashing (JET mini VS)
charlie belden
Having replace my JET VS mini's On/Off swith with a Three Way Switch, wired to add Reverse, I have, on several occassions been turning with a chuck and - not thinking - switched from FOREWARD to REVERSE rather than to the center position on the switch - which is OFF. My ability to dance improved dramatically while dodging the flying chuck - with its mounted chunk of wood. ( I know, I SHOULD HAVE installed set screws, with brass disk to prevent thread damage).
Apparently, having two or three pounds of metal chuck and another pound of wood spinning one way - at 2000 RPMS, and suddenly reversing the direction to 2000 RPMS in the other direction, and having the chuck and chunk of wood unthread itself from the drive spindle - puts some stresses and strains (and other forces) on the drive spindle, belt and bearings - and can, and in this case DID, result in 1/32" runout on my headstock end.
Using information gleaned from the archives on replacing bearings on a JET VS Mini I was able to remove the smaller drive spindle bearing, the upper drive pulley and the drive spindle. The larger bearing however has remained stubbornly in place despite multiple blows with a 2 lb dead blow hammer on the end of an appropriately sized dowel placed against outside ring of the inside of the bearing. Am considering taking a REAL heat gun (as opposed to the hair dryer units passed off as heat guns) to the cast iron holding the stubborn bearing. Will probably damage the nice white paint job JET put on the lathe, but a rattle can of white paint should fix that if necessary (why on earth did machine manufacturers switch to Machinery Green or Gray - to WHITE of all colors?).
SO -suggestions on non-destructive means of getting this uncooperative bearing out?
Two weeks without any turning - and no withdrawl symptoms at all - so far. Have been working on a portable, quick to set up and tear down three video cameras and supporting FRAME "system" which has been a great distraction. Will post a link to all the details with a parts list, parts dimensions, parts sources, prices etc. in case someone wants to put together one for their turning club. With the exception of five 7' long pieces of 3/4" EMT (thick walled electrical conduit), everythihng fits in a 22" wide by 11 1/2" tall by 50 3/4" ply box - that will have wheels. That's three video cameras, three tripod heads, three clamps to attach the cameras to the FRAME, three lights, four small video monitors, a video switcher box, a place for a laptop - and two 20" x 48" folding table and all the extension cords and A/V cables all in this one transport and store box. The other FRAME parts fit around this box and the whole thing can be rolled through a 30" door opening and lifted by one person into and out of a truck or van. Best of all, the system can be operated by just one person who can wirelessly zoom two of the three cameras in and out - no camera operators necessary.
Re: Bearing Bashing (JET mini VS)
It's not white...close, but not.
Ray - Middletown, in
I found Appliance paint in Bisquit to be the closest match to Jet white....that is, if you need it. Good luck.
Ray
