Revisiting CA tearout repair
Dave Staeheli
Many woods, although not all, really show a "stain" of CA glue when used in repairing a crack or defect. I turn a lot of birch and it was usually very evident
where CA was used. Almost impossible to sand or scrape out. I.D.K.H.I.K.T. but this works really well. Now I give it a shot of rattle can lacquer or sanding sealer first. I'm not even sure it has to dry first, although I usually do. Then apply the CA or filler and CA. Very rare to get any CA "stain" and have not seen any affect on using any finish.
I also keep on hand a variety of different filler materials. Usually anything powdered, like sawdust, stains a bit darker with CA than the original wood it was sanded from. So having a color pallet of lighter or darker filler materials can be useful. Used or un-used coffee, or instant coffee, works great around bark inclusions or knots.
Have also had some luck using melt in lacquer repair sticks, especially on lighter colored woods. The color match is the biggest problem for unobtrusive repairs. The lacquer stick colors are never quite right, and then after the finish is applied, the wood may change color but the lacquer repair doesn't. I often end up melting two different sticks onto the hot iron to get my color match of what color I think the wood is going to look like after I apply the finish. Sometimes I actually get it right. Really clogs the sandpaper though.
