more chainsaws
more chainsaws
more  chainsaws
jim 9 miles
Ok, I've read all the posts a few days ago- and I promise- no more low octane ethanol gas!
However, I still have a chainsaw that has sat for 6 months with it in it and it won't start.
What do our saw mechanics reccommend to get it running? Thanks!
Re: more chainsaws
Jesper, Denmark
Re: more  chainsaws
Jesper, Denmark
Dump the old gas, mix new batch. Do not use excess oil in the mix. 50:1 is currently the best recommendation - even if the saw is old enough to have a higher oil content originally specified.
Clean the air filter.
Clean the spark plug - use gas and an old tothbrush, NOT a wire brush. Don't use excess force in screwing in the spark pug. Hand tight plus 1/8th turn should do it.
Re: more chainsaws
Re: more  chainsaws
waltben
And if that doesn't work, remove, disassemble & thoroughly soak & clean the carburetor. Last step is to replace same. I've had to do this on a weed whacker and a generator. Doesn't seem to matter 2 or 4 stroke, ethanol gasoline just isn't good left in small engines that aren't used a lot.
Re: more chainsaws
It's not -just- the ethenol
Ralph Lindberg
All the additives in "modern" gas also help with trashing carb and gumming up the works.
Used to be that "gas" would last forever, today, eh, without adding in even more additives, maybe 30 days.
Re: more chainsaws
Re: more  chainsaws
Bob Conrad
Jim
Try giving it a squirt of Cyclo Break-Away. That's what my saw mechanic uses.
Re: more chainsaws
Re: more  chainsaws
Lan Brady
Bob,
Is that a tank addative or spray ti down the throat of the carb?
Lan
Re: more chainsaws
Re: more  chainsaws
Bob Conrad
Spray it in the carb. I have a hard starting Sthil, Took it to the dealer &
that's what he used. Seems to work better than starting fluid.
Good luck.
Bob
Re: more chainsaws
Re: more  chainsaws
Lan Brady
Thanks much.
I have poulan blower that tries to start, but just cant do it.
