Hairline Box
Since I've got several pieces of dogwood, I decided I'd try to do a box with a hairline joint. I wanted to preserve as much of a grain match as I could, so instead of the parting tool, I put a #2 blade in one of my jeweler's saw frames, slowed the lathe down to about 15 rpm in reverse, and carefully cut through for this.
Didn't consider, however, how I was going to hollow the cap as, at 2" diameter, it wouldn't fit in my extended chuck jaws. I thought about making a donut chuck, but wasn't happy with the lack of ability to gauge thickness. Reading John Lucas's post on his gun rack provided the answer however (thanks John) when he mentioned hot-melt glue. I thus turned a small chunk on a faceplate with a depression, centered the cap to run true with the tailstock engaged, and hot-glued the cap in place.
It was then simple to hollow the cap to 1/8".
I needed a retention ring to hold the cap on so I turned a piece with diameter to fit into the cap, parted off about 1", and glued it into the cap still in the hot-glue mounting
It was a simple matter to hollow through the block and trim the ring to fit. I then put the pieces together using the tailstock and a pressure block and returned and sanded the outside surface to match up both pieces.
My first-attempt hair line isn't perfect
But it's pretty close
Piece is 9" tall by 2". Comments are welcome.
Even snatched the bottom right out of box during a demo once because it was thinner than I thought. You know what happens don't you....well it has happened to me more than once. I am truly a student of hard knocks.
I have one of those "oriental" design pull saws with a thin blade that works like a champ for making the top cut-off where a thin kerf parting tool won't or shouldn't go.
