I made a boo boo
I made a boo boo
Steven Antonucci
I made a boo boo
Steven Antonucci
Have you ever buffed a burl piece with some inclusions using white diamond? Yeah, you are probably smarter than that... I'm not.
How can I get the white out of the cracks? It's cherry burl, and too pretty to paint...
Steve
Re: I made a boo boo
Carol
Solvent wash?
Skip Beardsley
Steve,
Been there, done that, got the tee shirt. I used and old fashion scrub brush and solvent, as Carol said.
Skip
Stuart Johnson
Try rebuffing with the Tripoli without adding additional to the wheel.
Ken Vaughan
Ken Vaughan
Gloves, mineral spirits, and a tooth brush. Keep refreshing the mineral spirits as you are seeking to wash the wax binder out of the cracks. The grit is ANSI 1200 - about 5.5 microns and should not be a problem once the waxey binder goes away.
Been there and done that.
Did not get the T-Shirt though.
I generally don't use the White Diamond..
jake Niedling
Very seldom to I use the white diamond any more because of the problem you ran into. Yes I have done that as well and deserve the t-shirt for it. I just don't really see a need for it most of the time, but I turn mostly domestic woods rather than exotics.
Float On
Some mineral spirits, then stipple with a acid brush, then use your compressor and a blow gun to blast the pits clean. Use a paper towel to catch the waste.
Re: Float On
richard hines
Steven, you could send it to and I can take care of it.
Steven Antonucci
Mineral spirits (round 1) has made it better
Steven Antonucci
reapplied and will see if I can make it even more better. Need to find a CLEAN old toothbrush in the shop somewhere...
Thanks for the suggestions
Oh Charlie!
Jim Rutten
Seems like someone could find a way to make that work in their favor (i.e. texturing a piece and then purposely buffing with white diamond for the effect). Where's Charlie Beldin when you need him?
