Gun Lamp Progress
Well it's slowly getting there. I'm working on the locking ring and locking mechanism for the top. I decided it needed little decoration so I added a split ring. What I did was glue up a ring. Then flattened it and hot glued it to a waste block. Turn the inside round. Then I sawed it in half with my scroll saw.
Turned a groove for the ring and then fit it in and clamped it in place.
This ring will fit over the door and keep it locked in place. There will be 2 brass pins and this ring will fit over those and then turn the ring to lock it in place. To keep this ring from rotating there is a locking lever that will fit into a slot so it will all be locked together. I should finish these as soon as the glue dries. Then it's on to finishing and figuring how to mount the rifles.
