At Last I finished a piece thats if no one here offers some great advice and I have to re visit the finished item More hours but nearly there
In the end I used the dremel bits as pins, I turned bone ones but I was doubtful they were strong enough.
After I had cut the pins I found I had used 3 brand new bits I have hundred of old ones that I keep in the hope they might become sharp again one day .
The pin holes you cannot see any evidence of as they were filled flush textured to match in with the grain of the antler.
Very hard to see the layering of airbrushing with my pour attempt at pointing a camera and pushing the button.
I tend to air bush then with a nugget brush go over the work to highlight the highs and detail
Airbrush again then highlight with dry brushing a light bronze to the edges followed by a very light almost undetectable silver.
I haven’t sprayed with lacquer over the top as I think the glossy finish may over power the detail.
Inside still requires some hand sanding as when I oiled this it showed up a couple of marks.
The green Puriri timber inside is a nice contrast to the green leaves.
The green on the antler is natural as id left these under a hedge for years
The sides of the vessel are a little flat for my liking but always a mission when there is so much height and only a small distance to form a curve
The underside of the burl I turned on the lathe and beaded then placed a 1947 half penny in to cover the screw holding on the antler. Epoxyied on the Antler and burl are one.
Comments for improvements if any always appreciated.
This is just my matter of taste, but the base, antler and vase just don't seem to work for me. I really like the vase, but just doesn't seem to work with the antler and base. But what the heck do I know about art, I turn things that I sometimes don't like, but the wife or friends really like. Your pieces always WOW me, but not this one. But please keep posting, because your work is inspiring to me. And I always need inspiration beyond the turning.
Terry your work as always is beautiful, that said I think the antler is to tall.I think if you cut the lower portion of the antler off so the vase is closer to the base it well bring the whole piece together.
Very cool piece, mate. I don't want to tack on any more work, but I'm just wondering how a smaller vessel put elsewhere on the antler might look? Just a thought.
