Anchorseal help needed
Rich Pearson in Mill Creek, WA
My brother had a large limb taken off of one of his maple trees today. It was from 20" to 23" in diameter. He had it cut into 16" - 18" long rounds which were then sawn in half lengthwise with a chain saw.
I will not be able to turn these into bowl blanks for a while as I am still in the midst of a player piano mechanism rebuild project for my grandkids.
I plan on leaving the bark on the potential bowl blanks and anchorsealing the end grain as well as the flat side, (i.e. all freshly sawn sides).
After sealing, they will be stored in a 60 degree area of my daylight basement shop for several months until I can get to bandsawing them into bowl blanks and turning them.
Should I do anything else?
Thanks in advance
Re: Anchorseal help needed
Paul Singer
If it is Anchorseal II I would double coat them and make sure they stay out of the sun. Put a tarp over them if necessary to shield them from the sun. I have lost many logs to the sun since Anchorseal II came out. It seems to not perform as well as the original formula.
Barry L Elder
I have always been told that the area between the bark and the wood is where the bugs go to begin eating. So I always remove the bark. Double coat the end grain, the long grain is up to you. Keep it off the ground and out of direct sunlight to also help retard cracking.
I think your doing about the best you can. I would second the need for a second coat. I have had my best luck saving blanks by coating them in paraffin wax. Right behind that is using 2 coats of Anchorseal.
Ahead of both of those is getting them out of the sun and wind and off the ground. The sun and wind speeds up drying and this almost always leads to early checking.
The bugs getting into the cambium layer releases the bark which also then speeds up drying which causes checking.
If you don't have inside storage I've found the best thing is to put one end on the ground and cover the tops with a tarp. That seems to be the best method for immediate storage. If I have time I'll coat the ends with Anchorseal. When I have just one good piece I will sit one end on the ground and cover the other end with a garbage bag. That usually gives me a couple months or more to get it further processed.
Rodney
Lots of good advice above and I certainly agree about about taking the bark off if possible because of the critters that probably have invaded there unless you actually want some "features". I've also seen some checking of the sapwood on half logs with the bark left on.
Since it was a limb, the pith was probably not centered and it is usually better to remove 1" or so either side of the pith for best results but that could be a lot of work at this stage. I think you might find the the wood with the pith left on checking from the pith side if stored. Temp of your storage area sounds good but you want to avoid "dry" as other posters have advised. Limbs also often have some internal stresses not present in trunks which can affect what happens as they move.
This is a good chance for experimentation in your specific conditions (specific local conditions do affect results). Make a few blanks and coat them completely with Anchorseal or, as suggested, paraffin and test how they hold up as compared with the logs.
Hopefully, even if you lose some you will still have wood to work with and more knowledge for next time and to share if you so choose.
jim 9 miles
Maple spalts beautifully. Might consider leaving some out in the weather, end on ground, no sealer and see what happen in 6 - 13 months.
