Need help with making hollowing tool
phillip medghalchi
I am trying to make some hollowing tools with carbide cutters and wondering that how i can make the shaft bent as like goose neck and at what radius or angle. Also, would be better to have round bar or square. Any help is appreciated.
To John Lucas, and any other turners who found my post int he wrong place. I apologize since this forum is little different that the other ones I subscribe. and, that was my first post.
OK, today I went out to a metal supplier locally and got Stainless steel 1/2" square rod 3 feet long and also same Dia. and length steel rod 1080 rod. However, I could not find the round cutters or the square cutters which the wood turning suppliers offer for these Carbide hollowing tools. I am sure some manufacturer is selling it to them just haven't been able to google or search it to find the main source. No disrespect to those suppliers, but some of their prices are to stiff and i guess they figure out that once one like me buys certain tool for turning then I ma off the market for long time, so they get their money up front form us. I just can't justify paying $300 + for set just to find out that I ma going to need larger size or the smaller size so as you can we turners would brake bank in order to do what we do.
Re: Need help with making hollowing tool
Re: Need help with making hollowing tool *LINK*
Sorry about throwing you over here but I know this crowd would like to meet you, will probably learn something from this discussion, and we won't clog up the "flat side" with "round" info.
I mentioned 1/2" simply because it takes a lot of leverage to bend 5/8" or 3/4" and if you don't have a way to heat it red hot it takes one heck of big heavy bending jig. 1/2" isn't bad.
Also you don't really need carbide tips. They are nice but do eventually dull just like High Speed Steel it just takes a lot longer. I have been using HSS to hollow for many years. It's quick to sharpen (and yea you'll probably need to sharpen it a couple of times per vessel but so what) I either glue the tips in the hole or use a set screw to hold them in. I think I prefer glue. I use Medium CA glue. (Cyanoacrylate or Super glue) If you use Carbide you will need to drill and tap a hole and ideally the screw should be made for that bit. The holes in carbide bits are tapered and if you force the wrong screw in you can crack the bit. Of course you can put a flat bottomed round head screw in to hold them. I assume your talking about the flat carbide cutters like EasyWoodtools. If you use the Hunter cutters the mounting angle and screws are much more critical.
As you can see in the first photo the bent tools have the cutter aligned with the straight part of the shank. This is very important because it reduces the twisting of the tool while hollowing. Make the bend to an angle you think will work. I have 5 different ones but you really only need one similar to the second one down in the photo.
The second photo is a detail of the straight cutter. You can buy these HSS 3/16" square cutters for 75 cents and they are long enough for 3 tools. You have to cut them and they won't cut with a hacksaw. notch the corners with a file clamp them in a vise, put a towel over them and break them with a hammer. Or if you have a Dremel you can cut them with a cutoff disc. Grind them to shape on the grinder and your ready to go. I'll post the video on how to do this below. It's at the very end of the video.
To bend them I use a bending jig I built which is a giant copy of a wire bending jig I have. Since you won't have one of these I made my first ones by clamping 2 3/4" bars in my vise a hair more than 1/2" apart.Then make a wooden jig with 3/4" holes to fit over the bars to keep them from twisting. You'll have to put a clamp over the wood to keep it from splitting. Then you can simply put the bar inbetween these rods and bend it using possibly a pipe for leverage if you can't bend it without that.
https://www.youtube.com/watch?v=M9G16ylEZHQ
Bigger is better
I forgot to mention. You will be limited in the depth you can hollow with 1/2" tools. Well actually 3/4" as well. I find with my limited skills that beyond 6" gets really tough with 1/2". The tool starts to chatter. 3/4" will go to about 12" before it gets really difficult.
If you do a lot of hollowing it's worth looking at some of the captured bar systems like Lyle Jamieson of the Elbow tool style. They take all the white knuckle out of hollowing.
Also the bottom tool in the group photo is a 3/4" straight bar with a round cutter I made from a piece of thick file. I annealed the file by placing it in a bed of red hot charcoal and letting it heat up and cool over night. Then I cut off a chunk, rounded it on the grinder and heat treated it so it was again hard enough to hold an edge. I've used this cutter for years to clean up tool marks left from my smaller hollowing tools.
Re: carbide insert tool
phillip medghalchi
Daryll,
I appreciate it very much, for this info. it helped a lot.
