Chainsaw starting question
Mike Rubes, Apex, NC
Hi guys,
I have a Stihl MS250 that's about 4-5 years old. It's got pretty light use on it, just from me helping cut down the occasional tree and slicing up logs for the lathe. I ran it about a month ago and it ran like a top. I've never had any trouble starting it, but now, I cannot get the darn thing to crank. I've cleaned the air filter, pulled the plug and let things dry out as I was pretty sure I flooded it, but still no go. It doesn't even sound like it wants to catch and go. I dumped the gas and put fresh in, but still, no go.
So, any suggestions from you guys who do this a LOT more than I do? The plug looks a little dark, but heck, I am no mechanic. I could replace that and see if it helps? Any ideas to get it running would be great. A buddy lost a maple in a storm last week and some nice and clear maple is waiting for me :)
Thanks,
Mike
Killer of internal combustion engines in Apex, NC
Re: Chainsaw starting question
Dick Coers
Pull the spark plug and lay it on the head with the wire attached. Pull the cord. No spark means a trip to the repair shop for me. Spark, then it's fuel related. Old gas these days is a killer. Gums up the carb, cracks the fuel lines both internal and external, etc.... If you get a crack in the internal fuel line, it will pull air and not start. Make sure the fuel tank is full to the top, and that may let it start with a cracked line. Gummed up carb, another trip to the dealer for me.
Dan Jechura
dan jechura
plug's are cheep. I would try a new one
dan j.
mjonesrdg
Based on your description, I would consider the fuel delivery component to be the most likely culprit. Start at the bottom and work up...check the fuel filter (it's at the end of the fuel line hanging in the tank) and blow it out. Next I'd check that the primer pump (red plastic bulb on the side of the case) was filling with fuel when pumping it. Finally, a squirt of fuel down the throat of the carburetor would tell me if I'm barking up the wrong tree.
Jerry Klug
Once you get it ready to run again, use NON-Ethanol gas. The old style gasoline that we all knew and used. There are gas stations that sell it for old car buffs. You can find one either on line or through a local car club. It is usually about 20% more than oxyegnated fuel but your small engines will last longer using it.
Cyril Griesbach
Mike,
With my Stihl saws I always use the Stihl oil in the black containers that has fuel stabilizer in it. And I still use the blue Stabil in all my fuel containers to help avoid the the fuel system destroying effects of the dreaded Ethanol. Also, I never mix more than one gallon of fuel for my saws at any one time which also helps to keep it more on the fresh side. All the other advice you've gotten so far is right on track.
If you've had non stabilized fuel in your saw for some time now it's possible that the fuel line needs replacing.
Dale Jablonski
Dale Jablonski
Remember, your gas needs to be relatively fresh. Gas/oil mix that has sat for a sustained period will affect the engines performance.
Alan Van Art
I go for long periods of time between uses of my chainsaw. I often have this problem and it always ends up that I forgot to turn the "run/off" switch to RUN. Makes me feel pretty dumb, but mostly it makes my arm sore.
Roger Chandler
I had a Stihl/Husqvarna dealer tell me just a few weeks ago.........90 percent of the issues that they see with trimmers, chainsaws and such are ethanol gas related............Husqvarna recommends no ethanol gas and high octane to boot. Ethanol breaks down in about 30 days and creates water and gums up carbs and will cause you all kinds of issues............
Stabil for ethanol gas will help, but it will only last for about 4 months at that.........just find a station that sells no ethanol gas, and then use regular Stabil in it.........you will never regret it. Use some carb cleaner to clean out the thing when you start it up.........spray some into the carb without the air filter on it.......might take a few tries, but it will help.
I have quite a collection of mostly ......
JamieDonaldson
...Stihl equipment that I use around the golf course, and have had more problems this year with fuel than all previous years combined! Seems if the fuel is more than 30 days old in the tanks it begins to degrade the operation, especially the starting, and I use the highest octane I can buy at the pumps. Give that corn to the cows, and lower our food prices! ;)
Re: I have quite a collection of mostly ......
Hugh
One time on an old Husky 61 chainsaw, I had a problem starting it. I tried everything. Finally took it to a repair shop and the fellow there took the spark arrestor screen off and cleaned it up with a wire brush. There was a lot of carbon build up on the screen and it was keeping the exhust from exiting properly. Saw started right up after that. Just a thought.
Hugh
Thanks
Hi all,
Thanks for all the great ideas. It will be Friday night before I get a chance to play with it again, but I will take all this into account and see what I can do to get it going. It's funny, I am really leaning towards the ethanol thing as, I kid you not, my mower and weed eater have died in the last 2 weeks as well. I guess the cars are tougher because it (knock wood) is still running!
Thanks so much,
Mike
Done with work for the day in Apex, NC!!
Philip Duffy
I burn aviation gas in all my small engines. Result is that I never have a problem with gumming or starting. Just get a can of 100 proof and be happy. Incidentally, the engines all love it. Phil
Can of Starting Fluid
Doug Wolf
I got tried pulling my arm off on various gas engines trying to get them to start. By the time they started I was too tried to do the work. So I bought a can of starting fluid at WM and haven't had any trouble starting ANY of my engines (weed eater, lawn mower, chain saw, etc). I use gas mixed with oil left over from the last season for my chain saw and weed eater and one quick squirt of starting fluid into the air intake does the trick.
If there is something mechanical wrong with your equipment then of course this won't work, but mine were running fine when I last used them. They just need a little help to get them going.
robo hippy
Aren't you supposed to yell 'Giddy Up!' before pulling?
I do run premium in my saws, and I never use the cheap gas station (Arco here). Found out with my car (Toyota Sienna) that by switching from Arco to Shell, miles on the tank (when the gas pump light comes on) went from about 320 to a little over 400. Slightly less with Texeco, Chevron, or 76 (about 360 to 370). You would think that the same octane lever from all the different companies would give pretty close to the same mileage.
robo hippy
High octane gas
My brother-in-law bought a Stihl string trimmer that displayed the same resistance to starting, so we called Stihl and they told us to use high octane gas. Worked like a charm.
