Gun lamp progress
Last night I planed and carved the walnut "door" V's. Then I installed the door and clamped everything together. I made a jig to ride on the outside of the lamp so I could route out a rabbit in the body for a ring that I'm going to use to attach the lamp to the base. It will also serve as sort of door lock with pins at the bottom so you have to lift the door up and out to open it. The top locking ring will prevent the door from lifting up and out until it's removed.
It's so nice to have a lathe big enough to turn these rings. Sorry about the focus on the second photo. I hate auto focus. It apparently decided to shift just as I took the photo. Should have previewed the image and reshot it.
I've used a ton of hot glue for this project to temporarily hold all the various jigs and clamps. I've also used at least 4 or 5 different chucks or wasteblocks to hold everything.
Later tonight I'll mount the lamp to the base and work on the door fit. It's not bad as is but I think I can glue a thin strip on one edge and make it fit much more accurately with some careful planing. I'll know more once I turn it over and remove and replace the door a few times.
