Turning Diamond Wood (sp?)
George Taylor
George Taylor
I have had a most difficult time turning colored plywood for my Beads of Courage project. I have an section of the stuff sandwiched between 2 pieces of very dry cherry taking my normal cuts and scrapes to hollow out the inside. I have already broke a tenon and a recess with 2 major catches in this stuff ruining some of the beading on the outside. I have never in my recollection broken a solid tenon. At this point I am going to have put a glue block to go after it again. When I do, I am tempted to drill to the depth and then use straight carbide scrapers to do the main hollowing. If it wasn't for BoC this project would be going to the "later" pile.
Anyone have any better thoughts on attacking
Re: Turning Diamond Wood (sp?)
Dymondwood
Somehow, I'm not surprised. Dymondwood is birch veneer impregnated with acrylic resin and crushed to half its thickness in presses. It must turn more like stone than wood.
I don't have a definitive suggestion for you, but consider using scraping tools with relatively blunt bevel angles.
Mike Stafford
Dymondwood?
Mike Stafford
Hi George,
What exactly is the problem? Are you having catches when cutting on the Dymonwood or is that problem occurring when you transition from one part of the sandwhich to another?
The point of the catch should be somewhat obvious on the exterior. I noticed you said you were doing some scraping on the exterior. Are you using the EZ wood tools? It could be that the cutters are self feeding into the softer material as you traverse across the glue-up. Are your cutters sharp?
I have some experience with Dymondwood and have only used normal turning tools on the exterior of objects and Hunter tools on the inside depending on shape.
Again I am guessing as to the nature of your problem but you are correct that a catch violent enough to tear off a tenon is a sure sign of a problem.
George Taylor
Re: Dymondwood?
George Taylor
Exterior wasn't the problem; I was able to use traditional turning tools; it was in hollowing the interior with gouges and scrapers where I was getting the issues.
Thanks for the follow-up
Mike Stafford
Re: Dymondwood?
Mike Stafford
George, what was your speed? Were you turning fast or slow? Depending on the material and the tool speed can contribute to whether the material cuts cleanly or even tears out.
Were you engaging a round cutter in such a way that more of its diameter was coming into contact with the material than it was possible to control? Sometimes I have found that to be a problem with round cutters. You can be cutting along just fine and all of a sudden you reach a place where a large portion of the diameter of the cutter makes contact and BOOM! you have a nasty catch.
I hope you figure out what was going on and don't hurt yourself. Be careful my friend.
Re: Dymondwood?
Emmett Manley, Lakeland, TN
When my supply of Dymondwood is depleted, I will never turn another piece. It is expensive, turns like concrete, stinks, the dust is very irritating and covers a shop, and it quickly dulls tools. If you are able to stick with it, the products can be rather attractive but not worth the time, trouble, and expense.
Don Leydens
Re: Dymondwood?
Don Leydens
Seems like you're not alone with your opinion on how that stuff turns. Emmit said it well. Even turning a pen with that stuff is no fun. Whenever I run into problems with stubborn cuts, I give the Hunter tools a try (with a fresh cutting surface). Many times they've bailed me out.
George Taylor
Hollowing Complete
George Taylor
Big glue block (with yellow glue), big tenon on big chuck, steady rest & EWT scraper got the big job done; then followed with light scrapes from traditional scrapers. A little sanding and then finish the bottom (jam chuck is already standing by) is all that is left before the finishing room. (whew)
George Taylor
2nd pic
George Taylor
