Patching tearout or defects
I don' t know if I can describe this properly but I'll try. I prefer to cut everything clean and not have tearout but sometimes you do and on a project as large even tiny defects can be a pain. Here's what I do and can often hide the defect so no one knows.
I usually do this after sanding through the first few grits so you have a good idea what is going to be impossible to sand out without leaving a divot.
I take some 180 grit and sand over the area until the sanding dust fills the defect. If it's a big spot I over fill.
Then I touch it lightly with thin CA. I let it sit for just a few seconds. Use as little as possible so it doesn't run. It helps to pull the piece off the lathe so the are is horizontal and the drop will sit and not run.
then wipe it off with the 180 grit and run a few times. This clogs up the sandpaper at that point so you'll have to shift to a fresh area. Then sand with the fresh area until all evidence of the CA is gone and the defect is filled with CA and dust. If it doesn't work completely do it again.
In some cases it will stain the wood but very often you can get away with it if you sand before and during the application.
In the case of this big lamp I had about a dozen or more little nicks here and there. I was able to patch all of them this way.
Re: Patching tearout or defects
Don in Central Illinois
Thanks, John. I have a piece of dry ealnut and am having a devil of a time with some tearout. Sharpen, light cuts, nothing seemed to work. I'll try it next week. Have to work on my grandson's bedroom. First things first.
Stuart Johnson
Another fix is to use a bit of yellow glue. Add a drop or two, start sanding while the glue is still wet. Works wonders on a face frame with a small gap.
Rob Wallace
Reducing tear out......
Rob Wallace
Don:
I have had similar problems with walnut, and tried "stabilizing" the surface by painting-on a 50-50 mix of Elmer's white glue and water, allowing it to dry, and then turning that away with light cuts with very sharp tools. At least for me, it markedly reduced the tear-out. I also tried the same technique with end grain on dry box elder (notorious for tearing-out), and it also worked pretty well.
Others have "stabilized" the wood with dilute shellac or spray lacquer, and some just wet the wood with water and refine the surface with shear scraping. Whatever it takes - including the "80 grit gouge".....
Good luck!
Rob
Steven Antonucci
cabinet scrapers feather it out...
Re: cabinet scrapers feather it out...
Steve That's fine for some surfaces but it will reflect light in an odd way if it's a broad surface and can show what you did. for bowls and platters I do that a lot but sometimes if it's just a pin head size hole it's more effective to fill it.
Dick Hines
Dick Hines
John another way to fix small pits and small cracks is to fill the spots with med CA and then before it dries take a piece of sand paper and as the lathe is turning pull the sand paper over the sopt. In this way you are pulling the sanding dust into the defect. I don't use thin CA for this because it tends to satin the wood.
This will clog up the paper. I save pieces of tri folded paper that I have used 2 sides for this. I like to start sanding a piece with a new tri folded piece of sandpaper so I always have some laying around.
