A different sanding method
Lyle Jamieson
I have a different take on this. I have found that I need to slow down...and use sharp sandpaper. Dull sand paper and fast speed will heat up. I dont want to heat up, period. If it is hot enough to burn your fingers what is it doing to the wood?? It is damaging and burning and burnishing the wood and likely starting cracking and heat checks. Wonder why you get a blotchy clouded area and the torn out grain still evident after sanding?? Dull sandpaper!!
So I need to slow the wood down as slow as possible 50-100 RPM or slower for larger diameter pieces. I do not want to use gloves or padding. I need, want the "heat sensor" of my bare fingers, they are an indicator that my sandpaper is dull and the need to move on to sharp paper. I want to feel the heat, but not hot.
When using power sanding disks I only use them for coarser grits. Think of a 400 or 600 grit disk spinning at 1800 RPM of a drill. As soon as it touches the wood, immediately it is dull and from the first second on you are damaging the wood with hot dull sandpaper. Wonder why you melt the velcro?? Dull sandpaper again!! Wonder why you burn your fingers taking the old sanding disk off the disk?? Dull sand paper going way too fast. Again, if you get that much heat, what's it doing to the wood surface, not a pretty picture. I use power sanding for 150, 180, 220 only. Then I switch to hand held 320, 400, 600, with the lathe running very slow or if there are natural egges or voids I sand off the lathe by hand.
More work?? Yes, but the results are worth it if you want to take your work to the next level. Use more sandpaper. Not really!! I only sand once. I sand with the coarsest grit I need to get and tool marks off or correct any torn out grain. After the first sanding is done from then out Im not really sanding but just going through the grits taking the sandpaper scratches from the previous grits. With sharp sandpaper and slow speeds it is quick and easy to go through the grits. I always stop at each grit for close observation. Did I find a flaw from the previous grit?? Go back a couple grits coarser and get it early in the sanding sequence.
