I started sanding this thing with my belt sander. Guess what, belt sander belts have a shelf life. I haven't used the belt sander in a year or more. I bought these belts about 4 years ago or maybe more. I've used a lot of them over the years but today every single one I put on broke in just seconds.
Soooooo, I held them in my hand and sanded until I got rid of all the tearout and leveled the walnut inserts. Then I pulled out the random orbital sander and went to work. That got rid of the scratches from the course belt but of course left little circluler scratches. I ended up hand sanding those in the grain direction. Man was that a job, almost like riding the bicycle many miles. I'm up to 220 grit now but the next grits will go fast because I've gotten rid of all the odd scratches. The setting sun is fantastic for seeing scratches.
I finished sanding to 220 grit. Then I took it off the lathe and removed the hot glued bottom insert. I drove a thin butcher knife that I usually use to break apart paper joints down through the door joint. It came apart easily. There is just a little spring to the unit which I will easily be able to close when I install the bottom so the door should fit perfectly when I clean off the paper.
A good way to clean up a paper joint if you used yellow glue is to use white vinegar. Let it soak in and take your time. You can scrape it right off. On some more delicate split turnings I tried just using the scraper any you can chip the edges of the joint. The vinegar softens the glue so you can gently use the scraper.
To put it bluntly, I think this $#%@ thing is actually going to work.
I've really enjoyed watching you work on this project and look forward to seeing more how you put it all together. I don't remember if you said how many long guns this was planned for and how they will be supported on the interior. Any thought to a lazy susan to turn the selected gun towards the door? Going to turn a wooded shade for the light?
Interesting idea. I had planned for just 2 but in the back of my mind was the possibility of more so I like the idea. Once I get it installed on the base I can work on the support system for the guns.
