Turning A Platter
Stuart Johnson
I think the first thing is to remember there is no one way and only that way to turn a platter.
My way.
1. Dry blank roughed out to approximate size.
2. Screw chuck in the top with a spacer if a thin blank. I don't use a glue block.
3. Outside shaped with a dovetailed recess in the bottom.
4. Inside turned and sanded.
5. Vacuum chuck used to final turn and sand the outside. I usually reduce the recess at this point.
6. Finished off the lathe.
This assumes I have been able to keep the bottom together. Many times I go back and forth between a dip and a dimple until the piece is destroyed. Doc Green talked about a scraper with a fine burr and I think that is the answer.
