Deep hole measuring
Deep hole measuring
Deep hole measuring
I was pretty darn sure my lamp was thick enough everywhere but I wanted to be 100% sure so I built this deep hole measuring device. The spring slides up and down in the hole and has markings every 1/4". I probably should have put a small ball or something on the non spring side to give it a better surface to register to the inside of the lamp but this was good enough. I just barely had enough room between the plywood that I used for the faceplate to slide the measuring device in.
I didn't get anything done on the lamp today. Had to take the car in for an oil change and other errands around town and then did some yard work. Then took a nap and took the dog for a walk. I might do some work tonight but more than likely will wait until tomorrow.
Re: Deep hole measuring
Jesper, Denmark
Jesper, Denmark
I can see that you are settling well into retirement, John: Taking a nap moves up on the priority list :)
Barry L Elder
Now you are losing some of the bad habits from "working". It's always better to rest for a day before moving on with critical hobby efforts! :D
routing for inserts
I decided to put some V shaped walnut inserts in the bottom at the joint lines. I usually do this with my index wheel but that would have meant removing the piece, installing the index wheel and re-installing the piece. I wasn't absolutely shure it would go back on perfectly and would need to turn these walnut pieces down to the cylinder diameter. Between that the fact that my glue ups weren't absolutely perfect and the joint lines might not match up I decided to just eyeball it and clamp it in place.
I glued the jig that I used to route out the top plate insert. I simply hot glued it to the top and then turned it round. I used parts from another jig I made years ago to clamp this jig to the lathe. then I just lined up the router bit by eye and clamped it down.
I ripped up all the walnut strips and glued them in. Now I get to run errands while this dries. I did not glue pieces in the glue joints. I will glue pieces on after the door is separated and just hand planed them to shape.
Hopefully sometime this afternoon I'll be able finish turning and sanding this thing and then cross my fingers and try to remove the door.
Malcolm Ray
Malcolm Ray
Thats the spirit,you are retired now........enjoy it....
Don't Forget......
jake Niedling
the other surface enhancement techniques. You might as well do some carving ( how about an eagle ), Add some Inlace, air brushing paints, Pyrography, etc. I know you can do it and you have the time now. Go for it all. :b :D
What a great idea John,
Mike Foster
necessity is the mother of invention!
I think I'll send it to Cynthia Gibson
for some serious pyrography work. Bet that would take a day or so to complete. :)
