Gun lamp progress
I had to take a break. Roughing this thing out is kind of tiring. As I noted before it's about 1/4" out of round. Turning it faster would make it easier but I've never turned a segmented item this large (46" and 32lbs) so I'm keeping the speed down. I'm more nervous about the hot glued insert inside that I mounted the faceplate too than I am about the lamp coming apart.
I've been playing back and forth with a large Crown roughing gouge and the Hunter Hercules. The roughing gouge leaves a smoother finish but is a little wearing on the hands. The Hercules with a big weighted handle is much more relaxing but I have to take smaller bites and it doesn't leave as good a finish. Probably because the grain in the wood is sometimes running in stubborn directions. With the roughing gouge I'm holding it at an angle that gives a slicing cut.
Because of some knots and swirly grain I'm getting the best final cuts with a 5/8" bowl gouge with swept back grind and doing a pull cut. The wings on this are narrow so they care quite sharp and cut very cleanly. I'm checking for high spots with a ruler and trimming them down as I go. I'll probably use the John Jordan shear scraper to do the final truing up.
The base and the rings are done except for final sanding. I'll be attaching the lamp to the base with screws in slotted openings in the base. I'll drill those later when I fit the thing together.
