On the subject of shop accidents:
Steven Antonucci
From time to time, it probably makes sense to recant our own personal tales of woe. There are plenty of obvious dangers standing at the lathe, such as being struck by the workpiece, but I thought I'd share three of my personal experiences.
First, I have a Nova 3000, and I have a handwheel on the lathe that is great for many things. Over time, I have used it as a braking mechanism when I am in a hurry. I have learned two situations where patience is a virtue. First, when your lathe is spinning at 3000 rpm, it will create enough friction through a glove to burn you. The blister serves as a reminder for a couple of days about your indescretion.
Secondly, when the lathe is in a lower speed, it is usually because there is a large spinning mass mounted. There is something called inertia, and it means that the large spinning mass will spin until it is darn well ready to stop. When the lower speeds are used, the handwheel is aproximately a finger thickness from the motor body. I say approximately, meaning slightly smaller. I know this because I have had my fingers pulled through this slightly smaller opening. It is the mechanical equivalent of hitting your thumb with a hammer. The effect is about the same duration as the blister.
Also, note that a Oneway lathe will stop when it is ready to stop, and the handwheel will gladly dislocate something for you if you try to disprove that fact.
Next, my personal experiences with CA glue. I shudder every time I see someone flooding a crack with CA glue, as it may not cure all of the way through. I did this, and then cut through the cured top while turning. The spinning piece threw uncured CA into my eye (yes, I should have had eye protection, but admit it, we all skip it here and there). It is safe to say that the chemical burn in my eye cause more pain that I can describe, and I would sooner use the handwheel every day as a brake in low gear before taking a micro dot of CA glue in the eye.
Lastly, I have been cut by attempting to catch a falling skew. It might seem obvious, but resharpening takes about as long as it does to stop the bleeding, and without the mess.
Let's hear about your not so obvious shop warnings.
Steve
