The Rowley earring stand drill jig
Mike in Southern New Jersey
Hello gang,
My daughter needs an earring stand or two and I have wanted to make her some of the Rowley designs but I just found that Craft Supplies no longer makes the steel indexed drilling jig. Not sure why its out of production but I was told by their CS person that it is. I see that there is some discussion written about replicating the jig in your own shop in a piece of acrylic but I'm concerned that the acrylic may not hold up very well and the holes will get too big with a few drillings.
Has anyone made the drilling jig from acrylic or another material? If so, please let me know how it has worked. Finally, if anyone wants to sell their steel Rowley earring stand drilling jig, I'm interested.
Thanks,
Mike
Re: The Rowley earring stand drill jig
Ken Vaughan
Ken Vaughan
Have not done that particular items with wood/mdf/acrylic templates, but have had success with those materials for a limited number of uses.
If you are using a hand drill, there is a tendency to have the bit a bit "cocked" to the side and ream the hole with each use. Drill press is much more consistent and allows more uses. Thicker is generally better unless you are just using the template to mark hole locations (transfer punches are great for this instead of use as a drill guide)
For 2-5 uses, acrylic should work fine as a drill guide. If your lathe has a indexing feature, that makes the layout easier.
Re: Rowley style earring stand pattern
Bill Jaclsonville, NC
You can print off any one of these templates and glue on top of whatever material want use for your jig and drill. Making adjustment to fit any diameter you want pretty easy too.
www.smithart.us/download
Thanks very much for the replies.
Ken said ......"If you are using a hand drill, there is a tendency to have the bit a bit "cocked" to the side and ream the hole (in your home made acryic template) with each use".
That is my concern.
I may be missing the point that some of you raised about using the indexing ring, which my lathe does have. As I see it, using the indexing ring for this purpose requires that I build another more complicated jig to hold a drill level and square to to the piece into which I want to drill holes.
Maybe the best solution is to attempt to make the drilling jig from a mild steel instead of acrylic, and take my time drilling holes. Any suggestions for me in that regard?
Mike
Mike Brazeau
I made a drill guide a few years ago using Lee Valley bushings. The smallest they have is 1/8" but no reason that a 1/32 increase would look that bad. A tutorial is available at http://www.ghwg.ca/techniques/Drill_Guide.pdf You could also make a bushing out of a piece of mild cold rolled steel and mount it as I did the LV Bushing.
Thanks Mike. You gave me a great idea after seeing the link that you sent with the drill bushings. I checked online and Lee Valley's are the best priced by far with some suppliers 5/32 bushing priced at almost $15 each. For my application, I can get a bushing......mount it in a block mounted to my banjo and use it along with the indexing ring on the lathe. Thank you very much.
Mike
George Taylor
George Taylor
My point was that if you are turning as thin (1/8 inch) as the diagram from Craft Supplies indicates, is being "dead on" on drilling a straight hole that critical?
gary clarke
why not glue your template to the wood and using the drill press drill the holes without a jig. Just my 2 cents
Mike Brazeau
Great. It is simple and works well.
Ken Vaughan
Ken Vaughan
Mike - it is my observation that people can and do see irregular spacing and alignment with holes in circles with only minor differences being spotted. I find that angular differences of a few degres in drilling holes in thin material are not seen. (My wife is a weaver and I have done prep work on bases for her weaving).
I have been successful with hand drilling holes having marked a circle and using the indexing function on the lathe. While the OneWay drill holding gear will provide greater precision, hand held has been sufficiently accurate for building jigs and doing "one of" pieces.
When I do use templates, I have found that use of my wifes Xyron device with repositionable adhesive cartritges allows me to use printed templates, and stick them to the wood, and them easily remove them without having to deal with residual adhesive.
For a "one of" - I would print the template, run it through the Xyron, mount it on a prepared blank using center to control the position, and with the index locked - and then drill away.
For a few -- I would make a simple drilling template with a circular mark and the indexing to and mark the hole -- use a scratch awl to mark/start the holes. and for from there.
For a bunch - steel templates and drilling guides make great sense.
