Video System for Demos - Parts 1 & 2
charlie belden
Wouldn't it be nice if every turning club had a video system like that used at the AAW's 2012 San Jose Symposium - or at least something similar? And wouldn't it be nice if the whole system could be packed up into a small, portable box - with wheels?
THAT is what I've been working on while waiting for parts to overhaul my little lathe.
The SYSTEM is made up of
1. a structure to hang cameras, lights and power strip off of
. . - that's easy to set up and take down
. . - is relatively light for ease of moving
. . - that doesn't get in the way of the demonstrator or block the audience's view
2. a Director's Station
. . - a table for everything to sit on
. . - a vertical panel with four 7 1/2" diagonal monitors (3 camera feeds, 1 outfeed to projector)
. . - a Switcher Box to switch the feed from any one of the three cameras to the video projector
. . - a power strip for four monitor transformers, a laptop transformer,a small podium lamp and an outlet for powering the lights and cameras on the "structure"
3. A box to put everything in or on - with wheels - that one person can get in and out of a truck or van
Here's the STRUCTURE - the frame made of 3/4" EMT thick walled conduit and 1" EMT thick walled conduit fittings.
Here are the top and bottom components with a camera mount. Three 7' vertical parts are not shown.
The tricky part was the clamp to mount the camera to the structure.
five 10' piece of 3/4" EMT conduit____$25
1" EMT conduit "fittings"___________$35
for the "camera mounting clamps"___$35
Total for the Structure alone _______$95
There's bound to be at least two people in your turning club with old tripods and video cameras their not using anymore so hopefully those are free.
While TrakLighting would be preferable, clamp on lights with reflectors will work so add another $25 for a pair.
Add a 5 outlet power strip for another $20.
For under $150 you're a third of the way to a portable demonstration video system.
The Director's Station adds another $200 for small 7 1/2" diagonal flat screen displays and another $50 for a useable Switcher. Throw in another $50 for cables and it's $300.
For $400 you're most of the way there.
Add another $50 for a folding table and another $100 for 1/2" ply for boxes and a set of wheels.
The whole set up can come to about $550.
Still a chunk of change but a LOT less than the AAW set up - $750 for just the frame vs $100 and their camera mounts, excluding the tripod head, have to be at least $50 a pop vs $16.
I'm working on some web pages on this and will post a link when I'm done; I hope to include details on cameras, switchers, small flat screen displays and so forth.
Have YOU put together a video system for your club? If so, care to share some details - and things TO DO as well as things NOT TO DO?
Re: Video System for Demos - Parts 1 & 2
Charlie Personally I think fixed cameras don't work for most demos. You constantly have to change which camera is doing what and quite often the demonstrators arm or shoulder is in the way or the camera simply isn't where it needs to be or isn't zoomed in enough or too much.
That's why I'm working with my friend Mike Zinzer to make this boom arm remote camera work. You can put the camera anywhere it needs to be and can zoom in our out to see the important details. There isn't any changing cameras. It does take an operator who is conscientious enough to work with it and we still have some details to work out. I'll keep everyone posted.
charlie belden
A boom mounted camera can be a great set up - IF your working in a studio putting together clips that will be later edited and burned to DVD. But for a live demo, you've got lights to contend with and an audience whose attention can and likely will be drawn away from the demonstration and to the large overhead moving object. With the FRAME and TWO FIXED CAMERAS that can be zoomed in and out by a single operator set up, the only moving going on is the demonstrator's. And if the demonstrator has a flat screen display showing what the active camera is seeing, he or she can get things he or she wants the audience to see In Frame.
The FRAME / CAMERAS / LIGHTS SYSTEM can work - once worked out.
Today I took the two still shots in this collage to see the range of fields of view a tailstock end mounted video camera has. Appears to be more than adequate for actual turning. For parts of the demo that don't require seeing the actual turning, no camera was needed before video and isn't needed with video cameras being used.
The tripod box the sample blank is sitting on is 20" long. The white foam board under the box is 30" wide and 20" deep. The hallway everything is set up in is 45" wide. The camera was fixed on a tripod and the two shots were taken with the camera zoomed back to its max for the Long Shot and zoomed in for the Detail Shot. The camera is off to the right of the imaginary lathe's axis of rotation. The sample "blank" is 8" long and 3 1/2" in diameter.
I disagree. The audience pays little or no attention to the camera. they are looking at the monitor and if you do your job right as the cameraman the video image will be so good that is where they will definitely look.
Lighting should be fairly even if possible so the lighting isn't a problem. When you have a light that doesn't work well enough or is in the way such as the Moffet lights that many people use, simply ask the demonstrator to adjust it or do it yourself. The demonstrator won't mind because the goal is to show the audience what they need to see.
I have run cameras at almost every symposium I'm been at. I often end up lifting the camera and holding the tripod to get better images. I always get positive comments on the video quality after a demo. The only negative comments were when I was physically in the way during the demo. The boom arm eliminates that but it's still not a problem if the image on the screen is good enough.
I was running the camera for Hans Weisflog when he turned one of his Saturn boxes. I stood right in front of the crowd and held the camera up in the air aimed down at the box so they could see the cut he was doing. Not one single person complained because they could all clearly see the cut on the screen which would be impossible to see even sitting in the front row.
There are many considerations to be.....
JamieDonaldson
...made before buying any camera equipment. Most video cameras will auto range on spinning subjects like turnings, and light levels should be low in the room to allow better viewing on a monitor or projection screen. Lighting at the lathe should be diffused to reduce washing out the image on screen. At this point in time a digital projector set-up, including screen, costs about the same as a larger LCD monitor, but like the screen, the monitor is difficult to transport without damage if permanent site mounting is not a possibility. The projection screen or monitor should be mounted to the R side of the viewing audience, so that the camera "person" working at the tailstock doesn't block the screen. I used this set-up for the 3 yrs. I organized the AAW Symposium demo video operations, and as always the weak link is the skill of the camera operators. A single club usually has many more engineers to assist than are available at a symposium, and the 16~18 demo rooms at AAW multiply the costs by that factor, including yearly storage and transportation from site to site, often cross country.
To Clarify Objective
charlie belden
To clarify my objective.
I'm going for an A/V System a small club can probably put together for about $500 or so, with some judiciious scrounging and some careful shopping, NOT THE ULTIMATE A/V SYSTEM. And it has to function adequately in a range of meeting environments that probably aren't ideal for this type of A/V presentation. We're after Standard Definition equiptment - cameras, switchers, and projector because they can be scrounged for free or bought at inexpensive prices and most old farts have experience putting Standard Def video stuff together from the old VHS Days.
In addition to performing adequately in less than an ideal venue, the SYSTEM has to be:
- easily transported in a van or truck
- easy get from truck or van to venue, unpack, set up, dismantle, pack up and get back in a van or truck and require only one or two people to do so.
- provide protection for the cameras, monitors, switcher box, lights, etc. when being transported and stored
- operated by ONE person (so wireless remote for zooming would be nice)
- stored in the minimum amount of space
So - with that in mind
- camera recomendations (maker, model no.)
- projector recomendations (maker, model no.)
- sources of above
would be really helpful.
