More Dogwood
More Dogwood
More Dogwood
Thought I'd let those interested see how cool this stuff cuts.
Piece is mounted long grain in prep for a small jar:
This is what flies off the skew:
The detail gouge makes "hair" doing end-grain ;)
This is also dry wood. When you cut it wet, the shavings are even longer!
Re: More Dogwood
Don Leydens
Re: More Dogwood
Don Leydens
Wonderful wood isn't it Mike? I was born and raised in NJ but never turned there. Now that I'm in NC, I'm glad that Dogwood is plentiful here as well. A wonderful wood to turn.
Re: More Dogwood
Re: More Dogwood
Bill McWhirter
Dogwood is by far my favorite wood. If water has gotten into it through a broken limb or such, you can get some beautiful dark browns and even orange.
I have started carving leaves and it is strong enough to allow for some very thin forms. It is also wonderful for making delicate finials and bases.
I just wish that it grew bigger. I have found some 50 year old "trees" that are less than 2.5 inches in diameter. I have also gotten a couple of 10-12 inch trees that grew in yards with plenty of sunlight, water, and fertilizer that were less than 20 years old.
Unfortunately there appears to be a blight that is causing a lot of them to die from the top down.
Re: More Dogwood
Mike Stafford
Re: More Dogwood
Mike Stafford
Dogwood anthracnose is one of the more destructive diseases that is affecting dogwoods in the south. It usually starts in the leaves and spread to the branches which die back. Trees in heavy shade seem to be most at risk but the risk can be lessened by mulching, pruning, watering and application of a fungicide. Of course this is much easier to do with plants used as ornamentals and the wild population continues to be at risk.
Some of the most beautiful wood I have seen in dogwoods came from trees with pink flowers. There tended to be pink in some of the wood.
The root ball of dogwoods can also be beautiful turning wood and was frequently used to make a mallet to drive the froe.
Re: More Dogwood
Re: More Dogwood
Jim Breeden
Excellent ! Dogwood is like cutting butta . :)
Re: More Dogwood
Re-Worked Dogwood
Trimmed and reshaped the cap from previous pix
Works better now.
Speaking of dogwood browns, I let this piece get a bit too far down the road to mulch as I could do without the yellow in the heart
But I decided to leave it rather than start in with the dyes and stuff. Being a member of the Round & Brown Corps, I rarely add color.
Re: More Dogwood
Some of those dogwood mallets......
JamieDonaldson
..were also used to whack around small white dimpled balls on golf courses. I just lost a 20 yr. old white dogwood in my front yard, but unfortunately its barely large enough to supply any turning wood other than some spindle pieces. :(
Re: More Dogwood
I love dogwood...
GaryG in MD
Unfortunately, so do borers.
We used to have a large, beautiful, white-flowering dogwood in our front yard. A few years ago, it went from appearing to be perfectly healthy, to being obviously dead, within a week. When the borers girdled it, that's all she wrote. I was very sad, but made good use of some of the wood.
This Asian-influenced end-grain cup (4" high x 3.5" dia.) was turned to emphasize the borer tracks, and a little bark, as surface decoration. ...Gary
Re: More Dogwood
Re: More Dogwood
Emmett Manley, Lakeland, TN
Dogwood is plentiful in this area of the country and I have lots of it on my farm in West Tennessee. Much of this dogwood is six inch diameter or larger, and I have harvested several trees 12 inches in diameter. It is a joy to turn.
Our dogwood has a pinkish hue and can be just gorgeous. Unfortunately, dogwood wants to crack and it is a constant battle to keep a piece from cracking, both before and after turning.
Also, as someone observed, dogwoods are fragile trees and it seems that half of the large dogwoods I encounter are dead or dying.
Re: More Dogwood
Don Leydens
Now you're cookin' Mark!
Don Leydens
The new top looks really good, Mark. Flowing nicely. Well done.
Don L.
Re: More Dogwood
Re: Cookin'
Amazing how many tools it took to redo that little cap.
1.Scroll chuck with extended jaws
2.Bowl gouge
3.Detail gouge
4.Small jamb chuck turned to fit
5.Small vacuum plate chuck with
6.Vacuum pump
Oh, almost forgot
7. 800 pound lathe :D
I need to look up the dude who told me this turning thing was a cheap hobby cause the wood was free :D :D
Re: More Dogwood
Mike Stafford
Re: Cookin'
Mike Stafford
Well, there you go....you were using way too many tools.....
All you needed was some sandpaper. I would have recommended 24 grit..... :b
As far as that guy who said woodturning is a cheap hobby I also would like to have a little talk with him.
