200+ woodworking book reviews
Final glue up of gun lamp
Well I knew this thing would be a problem. Ideally I should have done much more testing, used a different joint etc. However you do what you can with what you have. I got the joints as close as possible but knew that when I got to the 180 glue up it would be off. Sure enough. One side is 1/2" larger than the other. No problem. I allowed enough wood for that possibility because I've been there before. It will actually help when I fit the door.
The joint also doesn't close all the way and the angle is off about 3 degrees. I had planned for that also. I clamped the pieces together with a shim a little narrower than 3/32". Then I screwed on the end panels and added side panels to ride against the fence of my saw. Then I just sawed down through the 180 joint with my thin kerf blade.
The fit was nearly perfect so I glued one side with the paper joint and the other side with epoxy to give me enough time to work.
When it sets it will be time to turn it. I'm gluing a small disc in the small end. The larger end will have a disc also and will be screwed in using Pocket screws. I won't put screws in the door. I don't think it's going anywhere since it's been paper jointed.
I'm going to be taking a break for a few days to rest and do one more photo job for my former boss. When I left I knew they would not be able to replace me before Football Media day so I told him I would come back and work that. It's a job one photographer just can't do.
Re: Final glue up of gun lamp
Don Leydens
Lookin' good, John!!
Mike Foster
Wow John, that looks good from here. That is definitely on large glue up. Is your bed long enough to turn it? Use 2 lathes? Drill a hole in the wall to accept a live center and turn it that way (I saw Elsworth doing that in his shop in CO to turn something long. And a local turner here turned a 20' interior column for a town hall that he used a live center in the wall and a propped up Shopsmith to drive it). Looks like a cool project well under way. How is it going to open to get to the guns?
Galen Vetterick
John's has already given away the secret to the hidden gun storage. Maybe he should not go so far as to say how you break into the "vault".
Maybe:
Turn the main housing 270 degree clockwise to release the lower locking ring. Then turn the top ring 120 degree counterclockwise to release the upper ring.
Say the magic word and the housing opens into two sections to revel the guns.
As a gun owner myself this is a great project to see John work it out and how it will go together. Don't think I will ever try to copy John's turning on this one!
Looks pretty good from here.
