Morning lamp report
Starting the big glue ups this morning. I got all the rings glued up yersterday and will start flattening them this morning after I go vote. Well I might take a good hilly bicycle ride first and give the big glue up time to set so I can figure out how to glue the 3rd panel in place.
Then I have to figure out how to temporarily attach the door so I can turn the whole thing. I may use a paper joint but need to do a test. I would have to separate the paper joint using something like a guitar string pulled down through it. I usually drive a knife down and the joint pops apart. I don't think there will be enough flex to do that so I'll run a test on the guitar string method. If it doesn't mess up the wood that should work and would be much more stable for turning.
