Ash/walnut hollow form
Roger Chandler
New postby Roger Chandler » Tue Jul 31, 2012 10:24 pm
This one may have another trip to the lathe. While it looks a good bit better in person than in the picture [I am a terrible photographer]
I am not completely happy with the finial and the first pedestal I did broke [it was a better and longer form with better proportions] and I had only a piece of the walnut left which was too short, and left me with poor options on the transition to the bottom of the form body......it is too big, because I have a hidden 5/8" tenon on the bottom of the form about 5/8" long and that meant the transition point had to be bigger or else I would have turned through the walnut and messed up the already glued together form and pedestal.
Re: Ash/walnut hollow form
Tony Reynolds
Tony Reynolds
You have already pointed out all the problems, but it is a pretty piece of ash.
Roger It looks nice. I don't think the bottom pedestal is too short. I would like to see the thin area near the hollow vessel a little thinner. The same is true with the upper finial. That upper 1/2" could be thinner which would make the lines flow better.
Roger Chandler
Thanks John.........ever noticed how a finial looks smaller while on the lathe than it does when on a form? I had too many distractions away from the lathe when I was doing this one, and I think it broke my concentration...........a re-do may be in the works, however, it does look a good bit better in person than in the picture.....
I am not a good photographer, and somehow there is something that creates a bulging effect through the lens...........I think it is called "fish eye" or something to that effect........makes a bulbous effect.
Thanks for your critique!
Randy Gleckler
Roger, I think it looks great, Nice work
Roger I think the hardest thing in the world is to judge shape and size on the lathe. I will sometimes take the chuck off the lathe and place it vertical so I can better judge the shape. I had a friend who mounted a video camera over the lathe and turned it sideways so the image on the monitor was vertical. I think that's overkill but seemed to work for him.
Roger Chandler
Appreciated Randy!
