Simplifying Dick Powell's depth finder
Aage Rendalen
Aage Rendalen
I was intrigued by Dick Powell's depth finder, especially his use of a spacer block of wood, on the ways, to mark off the edge of the chuck (American Woodturner June). I simplified his system by making a sled that is the same length as the depth pointer. All you need to do is push the pointer into the bottom of the bowl or hollow form and the depth of the bottom shows up as a gap between the spacer and the sled.
Re: Simplifying Dick Powell's depth finder
Very Neat!
Cyril Griesbach
That should work just fine, Aage. However, I believe that if one would use a different chuck and /or jaw set a similar jig needs to be made for each different set up.
Hal Taylor
Great idea. Thanks.
Aage Rendalen
New hucks and jaws require new spacers
Aage Rendalen
Cyril, you're right. But cutting a spacer to fit a new chuck or a new set of jaws is a only matter of minutes. Instead of complicating things by using an adjustable depth dowel, I'm using a fixed one. For deeper vessels, I'd simply make another depth finder with a longer fixed dowel. The design is so simple you can make a new one in no time.
Steven Antonucci
Scribe a line on the ways for the jaw sets
Steven Antonucci
and simply set one block to the line.
The miniscule scratch won't hurt anything. If this is a problem, use a framing square to transfer the jaw position and painters tape.
Steve
Aage Rendalen
Good idea
Aage Rendalen
Since I only use one chuck, I'll keep using my spacer block, but for different chucks, your idea is great.
eliot d
One reason for a depth finder is to "see" the bottom of a hollow vessel so you don't go through it -- the old making a lamp shade problem. The best and most accurate system I've seen was demonstrated by Jorge Salinas of the Capital Area Woodtunrers: he simply put together a slight variation of the laser system many hollow turners use to judge wall thickness. So it's a straight rod, or whatever. with the laser dot aimed at its tip. You push it into the vessel until it just touches the bottom and watch the laser dot. That's it. (I just use my Elbow tool with laser essentially the same way. ) I remember chiding Jorge, saying,"Jorge, most of us just use a stick!" I got a lot of laughs, but Jorge's method is superior.
