This piece of spalted pecan came real close to being firewood (or pens). Key word being spalted. Kept on going anyway and this is what it turned into. 11" x 2.5" tall. My main objective was to make the sloping bowl bottom look like it was coming straight through the top. You can kind of see it in the very bad photo below.
Thanks for looking and all comments are more than welcome, Don
You nailed it Mike! Between the hard pecan, spalt lines and all the punky parts (many), getting an even cut (not to mention sanding) was a challenge. It was a good teaching piece though. I think I learned a lot by continuing with it.
An application of thin epoxy can make punky wood behave, if you're so inclined. I use either System Three Mirror Coat or Park's Glaze Coat which are thinner resins. For infusing into rotten wood, you can also thin it further with a little DN Ethanol; "little" as in not more than 5 percent. You can't do this however, if you're filling holes where the resin will set in a block because the reaction heat will boil the alcohol and you'll wind up with epoxy foam that's a mess to dig out and redo. DAMHIKT
Thanks for the tip, Mark. I was reading about that (maybe by you) earlier this morning and I printed out the info. Worth trying on the next punky piece. Shellac and/or CA glue just didn't cut it on this one.
Terry, I agree 100%. Had the wood not been so punky, I would have tried it. I tried something like that a while back and loved the way the piece was coming out, till a catch blew two of the legs right off. Next time I get some solid (and dry) wood in this general shape, I'll try that out.
