Got the staves cut.
Got the staves cut.
Got the staves cut.
I decided to use modified version of Keith Newton's glue up jig. There is just a small amount of cut to many of the staves. I'm going to put dowels in the jig to allow me to glue up 2 at a time on the left and right sides. Then I'll move the dowels to new holes and glue up the pairs into 4. There is a small amount of cut to many of the staves. The jig will hold them together and I can put some more clamps across the staves to pull them into alignment. That should save a lot of work on the inside. I'm going to leave the inside faceted but I would like the joints to not have any big bumps if possible.
As you can see in the photo I could feasibly glue up half a ring at a time and since I'm going to turn the outside the cupped boards really wouldn't matter but I'm going to see if I can correct that. I cut 10 extra staves so I could cull any that moved or had bad chip out from my jointer. It took almost 3 hours to cut all the boards to length and then miter both sides. I was really tired of clamping and unclamping boards from the miter jig but it worked perfectly.
I'm hoping by the end of the day to have the glue up done. While the glue is setting on all the joints I'll work on the 2 floating walnut rings. I have the 2 rings for the bottom glued up and will flatten them and glue them together today also. Boy is is nice having 8 hours a day to work. This project would have taken me 2 months when I was working.
Re: Got the staves cut.
matt overton
looks like it will work well. you have planned well. Retirement has you working full time I see!
Steven Antonucci
Visions of the guy turning with a chainsaw...:)
Steven Antonucci
Must be nice to have all the time you need to do what you want. Cabinet should be pretty.
Assume this gets turned into a big lighthouse on the Powermatic? If it was a lighthouse lamp, that would be pretty cool. You could make the top spin and still have the safe underneath.
Steve
Keith Newton
I'm not sure why you didn't leave the tab on one side like I showed, but I predict you will wish you had later. An extra pair of hands sure will come in handy when you try to put the clamps both sides at once.
Also, I scratching my head over why you are only going to glue pairs, instead of all, but on second though, maybe you should only try one pair the first time, then try to get the clamps on, just as a dry run first. Of course you know, that if your parts move right or left on the fixture as you have them, this will open or close the angle of the miters, so don't miss that one.
I would have sized the bottom jig to go all the way to the end, rather than a couple of inches from the end, as you have it. Because, when the glue goes on, the parts are slippery, and the ones in the middle, because of the wedge shape want to slip out towards the bottom end. I screwed a solid piece onto the side if the bottom arc to keep that from happening. And those 1x2s are not sufficient to prevent the side force from just pushing that part of the fixture over.
Let me encourage you again, to buy a half-round cutter, and matching flute cutter for the opposite side, then you can glue them all at once, and not have to worry about having that perfect angle, not to mention some of the other problems you are heading toward, and yet to discover.
Trying to help you reminds me of a Will Rogers joke.
There are three kinds of men:
The ones that learn by reading.
The few who learn by observation.
The rest of them have to pee on the electric fence
and find out for themselves. He he.
If you won't listen to what I have been trying to get you to do, could I ask a favor of you in return for the time I have spent trying to help. I know you could set up a camera on a tripod when it comes time to glue up. Would you send me a video, so I can at least watch the Chinese-fire-drill? I mean, so you can show me how easy this is. ha
Pete in Holland
Might want to cut out a disk for the near major and minor diameter to use as an interior gauge/form to ensure that your glue-up remains circular and not oblong. It can easily happen with such a glue-up.
Pete
Keith First off I really appreciate all the advice. I'm trying to take it to heart but working within my own limits. Even though I tried very hard to get all the angles dead on I know from previous experience that my skills and my tools probably won't be dead on. For that reason alone I don't want to glue it up all at once.
The reason I cut the tab off was so I could glue two pairs at once. Once I get the pairs glued I'll glue those pairs into 4, check the 45 degree angle and correct if necessary and then glue them into 8's, check the 90's etc.
I thought about buying some router bits but really can't justify the price for a one time project. I already have more money invested in wood than I really should but it's a one time project for my son. If I was in the market of selling these things I would do a lot of things differently.
As you can see in the photo I have dowels supporting the glue ups. I'll move those dowels down to the next holes for the 4 part glue up. Doing it this way gives me so much more time per section to work because I'm only dealing with one glue joint. The boards have a very small amount of bow and buy placing clamps at certain points and shifting the angle of the clamps I can pull the two parts aligned. There's now way I could do that with 8 or 16 parts.
Don Leydens
Don Leydens
I was thinking the same thing as Pete.
You're putting a lot of work into this, John, and by seeing your other work, have no doubt this will be a quality project your son will treasure forever. Keep up the good work!
Keith Newton
I didn't know it was for your son. Woodworking is my occupation, so time is money for me. So if I had to spend $200 for cutters that save me a day's work, I'd be crazy not to do it, especially if it ends up taking a lot more time not to have the tools.
Right now I do have time. I glue a few up, then work on the wood for the segmented rings a little, glue 2 more and do some more cutting or planing. By the end of the day I'll have much of it glued together and most probably have the segmented rings cut up and maybe glued together. For me it's all about time management since I also plan to do a good long bicycle ride today.
Keith Newton
Well, just keep in mind, that once you get past pairs, then quads, each level, your clamping method gets harder on your last glue joint, trying to open it up, which will be pretty hard on a newly cured glue-line. Those clamps between stations are going to be hard to apply pressure straight across the glue line.
I start the hard glue ups today
I'll keep you posted on how it goes. I'm more worried about the angles not being correct and couldn't really check those until I do this next glue up. It's really hard to check the 45 degree angles because I really don't have a tool large enough. The next glue up will give me 90 degree angles and then I can check those. Cross your fingers.
What I'm really worried about is the door. I'll bet there will be some custom fitting there. I'm also worried about how to hold the door in place while turning the whole thing. My original plan called for a paper joint that I would cut through with a piece of wire when I was done. I'm leaning toward hot glue now on the top and bottom and using band clamps for security that can be moved to different areas while I'm turning it. I think that would be much safer. The paper joint would be very secure but I'm worried about the gap left after I clean up the joint.
