Dancing on the Edge of Disaster
charlie belden
As a new turner who'd just bought a little lathe and a few tools, and had some Flat Work scraps around, every time I'd stick a piece of wood on the lathe, grabbed a tool and turned the lathe on - I was dancing with disaster. A few books and a video tape later, I had to dance out a little farther to get to the edge of disaster.
Then I got a chuck and it was a short trip to the edge of disaster. Then I tried doing a hollow form and danced on the edge of disaster with each inside cut/scrape. But a MiniMonster hollowing system move the edge of disaster back a ways
Going for Thin Walls moved the edge of disaster closer, but eventually I had to dance a ways to get to it.
Now I'm doing miniatures and the edge has gotten closer again, though disaster is more like disasterette. If I dance passed the edge there's disappointment, but no bleeding or wall dents. Oddly the concentration is greater, the adrenaline level almost the same as earlier dances with edges.
So what have been YOUR edges? Which ones have you danced off once and only once and stopped dancing in that direction? Which edge did you fall off a few times before you discovered where it ends and disaster begins? Got and Edge of Disaster you're thinking of dancing on? If so care to describe it?
