Lamp project moving along
Here is the mock up made from cheap wood just to work out the bugs on how to build this thing. I bought the good wood yesterday. It's all rough sawn air dried lumber. Today will be spent planing, jointing to true up the wood and then rough cutting the staves. Then I'm going to sit on them for 4 or 5 days to let the wood get to EMC in the shop and move however it's going to move. Then I'll cut the staves and start making the cylinder.
With Luck I may be able to save this cylinder and turn it into something. It's out of round due to poor wood and poor glue ups. I learned a lot from it but if I'm able to turn it on the lathe it will be fairly thin at couple of points. I'm thinking about making a sort of off set set of shelves from it. I'll cut the bottom at an angle so it will tilt and then cantilever two shelves out from it.
Re: Lamp project moving along
Dave Paine
I rarely build a prototype, but for this unusual item, I think it was a very good idea.
You already have a use for this. Arm rest/support while "supervising" others. :b
Well, that is looking good. *LINK*
Keith Newton
But how did you get there, it that from gluing the flat facets?
I'll ask again. Did you ever see the clamping fixture sketch that I posted?
I hope it doesn't seem like I'm badgering you, but since you never posted again, I wasn't sure you ever saw that post.
http://m.flickr.com/#/photos/7391658@N03/7606121944/
Re: Well, that is looking good.
Keith I did see it and it's genius. Will definitely go in my bag of tricks for future projects. For this one I'm going to use the discs on both ends. Screw the blanks to that and use old bicycle tires to clamp the sections one at a time. It will take longer but as I sneak up on the final 4 to 8 pieces I can set them in as a trial run and make some corrections if necessary.
