Is there a fix for stupid?
Dustmaker Mike
Morning all I was making a Circuit board pen the other day and had a slight problem. I have the Easy Wood pen turning tool and some how or another I had a catch which caused the epoxy or what ever the circuit board pen is made of to chip away all the way down to the board. Does anyone have a way to repair it? Some how or another I will figure out how to make these things with out a problem.
Re: Is there a fix for stupid?
Jim in Burlington Ont.
ReCast
Jim in River Oaks, Ont.
Hi Mike,
I have seen the same issues addressed over on the IAP (International Association of Pen Turners page)page. You can have the blank recast, there are some people on IAP who do that. My friend Cricket (AKA Marla) has recast a few for me in the past. Send me an email if you need some help with this.
Take care,
Jim
Mike Stafford
Mike Stafford
I can't help you with your problem but if you ever find a fix for stupid I am sure my wife would like to buy a few doses for her husband...... :\
I tried to explain to a fellow turner yesterday after he blew up his 3rd pen blank that bevel rubbing cuts will not do that. Or at least not nearly as often. Scrapers by nature pull on the wood more than a good cutting edge used in a bevel rubbing fashion, such as a spindle gouge or skew. My friend insisted on using a spindle gouge in a scraper fashion. I think his actual problem was using CA glue and not letting the glue dry long enough or not using enough glue. However I cut his last blank using the same tool only in a bevel rubbing cut and finished the pen for him with no problems.
Can't help you with the repair part although I think you could use a good clear resin of some sort and reglue it.
Don in Central Illinois
My wife wants sone, too.
Dick Coers
If you buy clear casting resin to recast, you will have more money in the blank than buying a new one. You can get the clear casting resin at Hobby Lobby with the 40% off coupon, and not have a lot of money in it. You will have to make a form out of non stick plastic to recenter up the blank. If the blow out is near the end, you can trim it back and glue on a contrasting piece of wood. You will have to add finish to the whole blank to cover the wood.
John is correct, I use a skew to turn all my acrylics and have never had a catch or blow out. A gouge will work, but will take more sanding. Some penturners even swear by bowl gouges, but they all ride the bevel to cut, not scrape.
Ken Vaughan
Ken Vaughan
Been there and done that -- snake skin cast in acrylic is particularly prone to be brittle, and can do that in the blink of the eye. The good news is that they will recast with clear polyester resin (recommended for snake skins) as that is probably what was used originally. Change of resins tends to be slightly visible.
Unless you are wanting to move to casting in resin -- take Jim's offer or there are other casters who will do that for a nominal sum.
I use Hunter or Eliminator cup type carbide to come in from the ends and avoid that buzzzzzzz of acrylic chipping. Bevel riding cut works best.
Some swear by the EZ style tools with acrylics -- but for getting the ends working I used the cup style tools tipped and riding the bevel with repeated success.
I finish with a honed skew and polish from there.
Yes!! dont turn pens
Terry Scott
BORING !!!!!!
Re: Yes!! dont turn pens
Dustmaker Mike
well the way it is going now I agree. but I have a few I need to sell to pay for a few tools I have bought. Thanks for all the reply's I will see what it cost to repair or replace.
