Redwood "Island" Tables from the "Flat Side"
Alan Young
Hello from the flat side of the world!- I admittedly seldom drift over to the world of turners but I just finished a set of accent tables with bases that feature turned poplar posts. The turnings are nothing to write home about but the overall look seemed to be an acceptable point of design for this board--anyway as posted earlier on the flat side:
Nearly a year ago I was approached by some clients to build bases for three slabs of Redwood they had obtained when they lived in the Pacific Northwest. The slabs are just under 2" thick. The long slab is a little over four feet long.
After some playing around with ideas for bases we settled on a "post on disk" concept.
The sketch shows the bases in a wood tone but the end design was to be a black base supporting the slabs.
I was into the project a bit before I started taking process photos. The posts were made by laminating 7 pieces of poplar, then turning them on my lathe..
The supporting disks or "plates" were also made from poplar. The disks received a routed ogee profile.
The bases received an initial coat of flat black. This was sanded back then a second coat was applied.
About this point in the process I had purchased and HVLP turbine and spray gun. Although the black was initially brushed on ,subsequent coats were sprayed including the top coat for both the bases and the Redwood Slabs. The top coat was a satin acrylic polyurethane.
Yesterday I delivered them to the owners who are happy to have them now as accent tables.
Thanks for looking.
-Alan
