A mini epiphany
charlie belden
When I entered the world of woodturning I had to overcome the preconceived notion that taking a sharp piece of steel to a turning chunk of wood - seemed obviously INSANE.
Fast forward a half dozen or more years and spindle turning, eccentric turning, multi-axes turning, box turning, weed pot turning . . . seem no big deal anymore. And The Dreaded Skew has become and old familiar friend, after acquiring a curve. Even doing hollow forms were possible, relatively easy to do with a MiniMonster hollowing system.
The Bowl Gouge remained a SCARY TOOL, but I'm overcome my fear of it - at a snail's pace.
A winged natural edge bowl, however, was still on my THATS INSANE list - until yesterday.
Spinning half of a two foot diameter log - with the bark still on it - and turning INTO the bark? THAT'S INSANE.
Spinning a two INCH diameter piece of a juniper branch - with the bark still on it? That's just a little bit crazy - but not INSANE - and worth a try.
Turns out the turning isn't that hard. Getting the tips of the wings at about the same height, and the low points of the rim at about the same height - well I'm still figuring that one out. Would be a lot easier if the branch was round - and the growth rings were parallel to each other and centered on the branch.
If there's a type of turning that seems intimidating so you've avoided trying it - test the waters doing a miniature version. Branches are far easier to come by than logs - and the quantity of shavings to clean up can be swept under the rug, or the rubber mat in front of your lathe. If something goes wrong, a spiral cut as an inside bowl cut is initiated, a chunk of bark flies off in your direction - even the piece exploding while being turned - it won't be a NEVER AGAIN thing. Mount another little chunk of wood and try again.
I know I'm sounding like a broken record (remember when music came on vinyl disks, or, if you're REALLY old - wax cylinders?) - if you haven't turned any miniatures yet - try it - you'll like it/
But, I do have some Black Locust I'll be trying out these new scraping techniques on.
