I have been in the shop---But
I had to go out and play for a while. I've been working on the lamp project and also working on the boom arm modification for video cameras. It's coming together. This is really going to help clubs present better videos of the turning action because it will allow you to get right in where a camera needs to be without the videographer being in the way. Of course in theory if you can see the monitors well enough you should not need to see the demonstrator because the camera will show you what's important.
I'll post better photos and plans when Mike and I get it to the point of really working well. We're close. This will let you tilt and swing the camera so you can have the camera looking down almost seeing exactly what the turner sees.
Re: I have been in the shop---But
Mike Gibson
That's the way John, work in your workshop all week and relax at the weekend.
Great Shot. Michael
john lopez
Retirement must agree with you John, you look younger already.
Jesper, Denmark
Jesper, Denmark
Hi John,
I wonder if the idea of presenting te video shot from the view of the turner realy is the right one? Check out this rather long video interview of one of our local turners, made by the local TV station.
http://www.youtube.com/watch?v=kkbn4m7SRDs
The camera angle is from the other side of the lathe and shows the tool action rather well. My thinking is that in many cases, the turner really cannot see the tool actio, but presents the tool by feel and experience. Shot from the other side of the lathe, you can see the tool action much better.
Incidentally, the tool used for detailing is a local "invention" reerred to as the shadowmaker. Essentially a Skewchigouge sharpened to a long point, which allows you to get in tight and make crisp details.
Lloyd in Mississauga
Depending on the turning being done, there seems to be a couple of key camera locations.
With a face plate piece, if the camera can be slightly in front of the piece (towards the audience) and above it towards the tail stock end, so that you can see the flute action it works well. One of the problems can be though that the auto focus on the camera does not click and you fight with that.
The other location would be an "over the shoulder" sort of view for spindle and outside of a faceplate work. Once again, likely more towards the tail stock end than right over the shoulder so that you do not have the turner blocking the shot.
With this type of boom, placed off the end of the lathe, but reaching in over top, the side ways swing would allow for the front or back shots and your pivoting platform aids in that camera position.
Have you looked at putting a pulley under the platform and back to the boom base linked with cables so that you can position the camera on the platform looking straight ahead, and then as you swing the boom side to side, the cables turns the camera with the boom so that you can keep the camera on the turning without needed to manually move it. As the boom swings, the camera platform would twist to keep the camera pointing at the same general location. Then the cameraperson would only need to worry about the up and down of the shot. You could rig a similar system for up and down motion of the platform as well. Add a couple of fine geared cranks to the support post for the cameraperson to move the boom in its too motions.
You'd need a way to initially zero it out, and then lock it in so that you have some adjustment depending on the piece being turned. Add in a remote zoom to the camera and viola.
Lloyd
With this boom which is on a rolling platform you can put the camera where ever it needs to be to get the best photo. You can stand off to the end, Go over head, go out front. Heck you can even look over their left or right shoulder when hollowing bowls or vessels.
The only real downside so far is that it requires a remote zoom and the camera operater must be able to see the large monitor to position and zoom the camera. That's wasn't a problem at all. When Mike and I get it done we'll do a lot of testing to see if anything needs changing. He's coming over today to look at what I modified. I have a couple of minor changes to make and then will take it down to the TAW meeting a week from Tuesday to try it out and see what else needs to be changed.
Looks interesting
David Walser
John,
It's good you were able to spend some time out of the shop. (Shop time is my play time, but I understand the theory that there's such a thing as too much time in the shop.)
Your video boom looks promising. If the plans are ready in time, perhaps we can use your boom to video your demos at the upcoming DWR. At past symposiums, I've spent most my time running a video camera. You're right, it's hard to give the camera a decent view without the videographer getting in the way. You boom could be a boon.
Re: Looks interesting
David Mike came over this afternoon and we played with some modifications. He took the boom with him and we are going to try it out tuesday at the club meeting and see if any other modifications are needed. I think it's getting close. I plan to put together an article on it once Mikes happy with it. It's his idea and I think it's a grand one.
