Robust Tool Rest Question
jake Niedling
I am planning to buy a Robust tool rest and I see they have two styles ( standard profile and a low profile ). Which one do you like? I was thinking of getting the low profile. Appreciate your comments.
Re: Robust Tool Rest Question
charlie belden
You didn't mention the swing capacity of your lathe or the size of the biggest stuff you turn or are thinking about turning.
I've got a JET Mini VS with a nominatl 10" swing so I got the low profile. Were I on a Stubby, Robust or maybe a VB36 . . .
Roger Chandler
I have the low profile in a six inch rest....really like it a lot, as it allows me to get in close, and when I do a finial, I can reach my index finger of the left hand behind the finial for support on delicate cuts. I can use it well in spindle work and to get behind the form next to the chuck and headstock without having to worry about busting my knuckles.
Your mileage may vary.......
Dave Paine
I have a 16in swing on my lathe. I purchased the standard profile.
I presently have 3 Robust tool rests, different lengths, so I could be considered biased. :)
Jake I bought the low profile because I often reach around the rest to hold thin spindles. I find it plenty sturdy.
ihmserv
I have the 12" standard robust, for bowls and larger turnings.
I have the 6" low profile for finials, pens. and small spindles.
both are used on a pm3520b
IAN
Thanks for the input...........
jake Niedling
I was planning on the 6" low profile mainly for the christmas ornaments and finials I do. It is for my PM3520A lathe. Thanks for the input.
