Burl Help
Burl Help
Bob Moffett
Burl Help
Bob Moffett
I am turning an oak burl bowl about 12" in diameter by 7" tall. It has several voids and a large crack on one side running from top to bottom. I have put medium CA into the crack and so far, it has held together. I have been turning about 500 rpm and have pretty much finished the outside. Now to the inside. I would appreciate any suggestions on what I can put around the outside of the bowl so that I can turn the inside without it coming apart. The outside does not have any finish on it yet. Thanks, in advance for any and all suggestions.
Re: Burl Help
Re: Burl Help
jim 9 miles
Fiberglass reinforced packing tape. metal band clamps
Re: Burl Help
Mike Stafford
Re: Burl Help
Mike Stafford
Bob, clear stretch wrap is perfect for the application you describe depending on the shape of the bowl. Just wrap several layers around the piece and top with some tape to keep it secure.
Another option is to create a wooden ring or two sized to fit the outside of the bowl in one or two places and hot melt glue them in place to secure the bowl. When you are all done take a heat gun and remove the ring and glue.
Re: Burl Help
Don Leydens
Re: Burl Help
Don Leydens
Bob, I have some pallet wrap that works quite well. I'll bring it today and you can see if you'd like to try it.
Re: Burl Help
Re: Burl Help
jerry bennett
Bob, it is good to be wary. This is the exact scenario that has unintended consequences. Even with the bands and tape, please stay to the side. If it comes apart, the immediate impulse is to turn the lathe off. Usually to do this you get into the lie of fire, not good. I witnessed this at a club meeting in west Texas a couple of years ago that resulted in a trip to the hospital and many stitches. Several guys had diligently poured ca glue into the crack and pronounced it good. This also just happened to a friend of mine a couple of months ago in Houston. He is just now healing up enough to start turning again. Either remote the switch or rehearse where the plug is.
Voids are not usually a problem, but cracks top to bottom are an invitation to the front seat of a thriller. Turn at the slowest speed possible. The best option is get another piece of wood.
Jerry
Re: Burl Help
Re: Burl Help
John Veerkamp
I love to turn pieces with voids and cracks, I use cheap vinyl electrical tape to wrap the outside. Shrink wrap plastic also works well. The plastic shipping wrap as mentioned by others also works. too much wrap is not a problem. Enjoy.
Re: Burl Help
Bob Moffett
Re: Burl Help
Bob Moffett
Thanks for the advice everyone. I will be careful and use some of your ideas.
Re: Burl Help
Re: Burl Help
Terry Scott
Id turn a ring out of mdf that fits over the out side and hot melt glue it on Works a treat
Re: Burl Help
MDF must be better where you live.
Keith Newton
Terry, you don't give any dimensions, which leaves a lot of room for a false sense of security. While you may be thinking of a 6" cross section, someone reading your suggestion may think 1" would be fine, which I would think was not worth the effort.
Are you sure this is a good idea? Have you ever looked at the numbers of what the forces are for different rpms at different diameters?
I have had a couple of blanks fling apart through the years, one of which hit a florescent fixture 12.5' up, broke the tubes, and bent the fixture. Luckily, it didn't fall back on my head. A few of these events, makes it easier to make the decision to toss a blank into the cull pile.
Re: Burl Help
Re: Use ply 1 inch
Terry Scott
Size doesnt matter I can turn 1100mm dia on my stubby so that is the biggest ring I can add
This is also great for supporting a bowl if you are turning thin
Ive also used this system if I want to or have to use a steady the steady runs on the ring and not the work
Imagine a 16 inch deep hollow form with a ply ring placed 2 3rds from the top .means you can finish the out side shape at the spigot.I will shortly have a dvd with the how to
