lamp progress
I built the taper jig yesterday and started cutting staves. I'm using some cheap furring strips for practice. I needed practice on everything from cutting to glue ups. Good wood is too expensive to screw up so this will be a good test. If it comes out reasonably successful I'll use these scrap pieces for some project.
Gluing up in packs of 8 was a real pain. I put tape on the back. When you try to open the joint to spread the glue it sometimes comes off the tape a little. this makes it hard to get the joint really tight roll it back together.
Another problem is wood that isn't truely flat or has tendency to twist when I cut it. As you clamp the wood there isn't good way to knock all the pieces into alignment like you can when you glue up a flat ring. As you can see in photo 2 there are some miss alignment problems. I'm hoping when I go to good quality wood and take the time to true up all the boards before I start cutting that this problem will be somewhat self correcting.
I'm trying some 4 stave glue ups this morning and the first one went much better than the 8 stave glue ups.
The bottom photo is my stave cutting jig. With the new Forest blade it is really cutting well. The only problem I'm having is the boards seem to warp a little after cutting but then this is about the cheapest lumber you can buy.
