Oak Trefoil, a collaboration
Mike Foster
This is a collaboration between myself and Andy DiPietro. Andy saw my Trefoil piece at the Totally Turning show in Saratoga Springs this spring and thought that it might make a great collaborative piece with me completing the form in oak and let him sandblast and finish it with one of his great finishes. I had to think about it some, as I have only done one offs, but finally decided it was really a great idea. I got back to VT and started looking around, but came to realize that white oak does not grow this far north. Andy and I were both doing demo’s at the New England Woodturning Symposium in Derry NH a month later, and he brought me up a chunk of some chestnut oak for the collaboration.
The trefoil form is pretty much the same as the first piece. This minimal surface has multiple iterations and I considered doing a piece with 8 lobes (4 on each side) but figured that would be too symmetrical, and more than that would get to be too busy, so I stuck with the original form. The base was bit of a different idea I came up with that I thought would give it some lift. It took some time to turn as it had to be turned and hollowed from both ends to match my concept of the final form, and stepped at the top to hold the piece securely. I wound up re-chucking it several times from both ends and used a steady help to complete the turning. The legs and arms were then carved out of the turned form.
I then sent it off to Andy to do his magic and left all those decisions to him. He decided to do his Oakobolo finish, and I think it works perfectly. I love the sandblasting combined with the color treatments that he has been doing.
This was my first collaboration, and I have to say it is an enriching and fun experience. You certainly get more out of it than a nice piece of work. We will be doing another, as we have decided to keep the results for our own collections.
I posted it yesterday on WOW and had a question on how I turned it. Well the answer is it is turned on 7 axes, but it still involves a lot of carving. I included a pic of the piece being turned that should be sufficient to figure out how I turn it. I actually turn it between centers into an ellipse shape first, then the 6 scallops are dished out and the centers hollowed from both ends. From there it's all carving.
Trefoil form
Chestnut Oak, Andy’s Oakobolo finish
6” H x 7.5”D
Stand
Maple, USMC black leather dye
7.125”H x 4”D
13”H x 7.5” D together
Andy did the photography
Re: Oak Trefoil, a collaboration
Impossible. This can't be done.
AwsAwsome.  You guys pulled it all together.
Jim Breeden
Mike - From a true nonprofessional turner, maybe in 40 years, how did you hold that ball in the chuck while turning? I can see the angle blocks to keep it from being slung off the lathe, but how is attached to the chuck? :\
Steven Antonucci
How fun is that?
Steven Antonucci
Collaboration.
Great work.
Making 2 of them.
keeping one each.
Priceless.
Steve
charlie belden
The trefoil is a tour de force of chucking, turning and carving. And the surface treatment and coloring is as well. But it's the support that would really cause me fits. Getting each of the "fingers" at exactly the right spot on the underside of the piece (if this has an "underside") doesn't seem to have much margin for error. Be off a bit - and the piece won't sit right on/in it.
Did you get that right - the first time?
Pieces like this must be hard to integrate the two parts to create a symbiotic whole. Did it give you any grief or did you get it the first try?
This is a great collarborative piece - that neither of you could probably pulled off individually.
Yes!!
GaryG in MD
Somehow, English just doesn't have the word appropriate for this.
So I'll switch to German --
ausgezeichnet!! ...Gary
Mike Foster
Thanks Charlie. Yes getting the fingers to fit was a bit fiddly. I turned the stand to the final shape I wanted first, with the bell on top a bit larger than a circle that would just touch 3 points of the form. I then hollowed out the top some and started fitting it to the piece. I first hollowed till the outside of the form was close to what looked to be the right diameter, but the form won't sit down in it because of the curves. So I wound up carving away about 1/4-1/2" of the turning that would be gone anyway after final shaping. This left stubby fingers slightly wider than the final form and allowed me to fit them to the form. I also created a step in the fingers to keep it from sliding down. Actually sits in the stand quite nicely, but only one side, as the two sides aren't exactly the same. I did actually get this right on the first try. I was pretty amazed that I could pull off what I had in my head on the lathe.
Mike Foster
Jim, the dished out shapes were turned between centers. It just happens that the headstock center is a bit whacky. I couldn't use a regular drive center, as it would have to bite into the wood at steep angle in order for me to scoop out the scallops as I wanted. To accomplish this, I made this jig. The blocks all hold the piece oriented as I wanted pretty well with the tailstock pressure. The form did wiggle just a bit, but that was easily solved with a bit of hot melt glue. The really nice thing is that I could turn all 6 scallops on different axes with the same jig. So, no chuck involved in this part of turning the form.
Thanks everyone!
Three-Part Harmony
It sings :)
matt overton
Spectacular as usual. How much different was it making the second one since you only have done one offs? Did you find it went quicker than the first?
Totally Fantastic!
Don Orr
Incredible collaboration ! There are not enough superlatives to describe this piece. I was standing nearby when you and Andy were talking about this at Saratoga. I could not even imagine what would come of it. I certainly am amazed by the results.
You guys are awesome!
Jim Breeden
Mike, I apologize for not mentioning that your collaboration is a truly remarkable piece of art!! ;) And, thanks for the info.
charlie belden
Mike:
Thanks for the description of what went into doing the pedestal. It's usually the central piece that gets all the attention, and the enhancement Andy added, but it's often the supporting characters that have the tougher job and get little if any notices. The trefoil is fascinating, made more dramatics by Andy's contribution to the collaboration. But, by lifting it up with the right pedestal, a Whole is created that's greater than the sum of its parts. The supporting characters - the actual support for the piece - figuratively and literally takes it up a notch, in a very unobtrusive but quite effective way.
That the pedestal worked out the way you'd originally envisioned it was no accident, given your attention to details, conscious or not. It's that thinking it through more thoroughly and then executing The Plan that makes your work so interesting.
Leo Cuellar
Superb!
