really difficult glue up
I'm designing a lamp gun cabinet for my son. He lives in an apartment and doesn't have a way to lock up or hide his rifles so I'm designing a lamp that will store and hide them.
Here's the problem. It will be stave constructed with 30 staves. It will be 14" at the base and 5" at the top and will be 45" tall. It will have to be done in 3 parts because it's going to have small Walnut staves inserted every 120 degrees that will stick out beyond the surface so they will have to be glued in later. 2 of them will help conceal the door.
Ideally I would like to turn this tapered cylinder and will probably use paper joints at the 120 degree point to hold it together.
I think I can glue these up 10 staves at a time using tape on the outside and then twine in a turniquete sort of thing to pull the staves into position and hold until the glue dries.
Anyone have any better ideas.
I didn't have the Walnut staves in the drawing. I decided on those after this drawing to add both visual interest and to help hide the inaccuracies that I'm probably going to encounter when cutting 45" long compound miter staves. I think between hand planing the 10 ring segments and fine tuning the walnut staves I can take up any gap. I know my saw is not that accurate but will be using my new Forest blade so it will be a good test.
Re: really difficult glue up
Mike Stafford
Mike Stafford
John, one thing I have used to glue up tapered staved constructs is shrink wrap. You can stretch it very tightly and it will compress the glue up equally all the way around.
You can also hot glue blocks in strategic locations and use them to prevent the rubber band or strips of inner tube from sliding down the taper.
Lastly 3M makes a stretchable packing tape that is sticky but stretches. It holds really well and by stretching it the tape compresses the glue up.
Mike I do have stretch tape and will probably use that. I wasn't thinking clear this morning. I'm thinking that if lay out the boards and cover the back with several rows of nylon packing tape that should keep the boards aligned. Then I can flip it over and apply the glue and then roll it up and wrap it with the stretch wrap.
I would like to clean up the glue on the inside while it's drying so I'll have to leave gaps so I can reach in. It will be a very big pain to do after the glue dries.
Still trying to figure out how to cut the 45" tapers. I will have to build a jig to hold the wood at the proper angle and then be able to flip the board on another jig for the other side. Boy there's just all kinds of room for errors to creep in. I'm beginning to think Clay Foster has the right idea using concrete. :)
Dick Coers
Use a sled on a thickness planer for the tapers. I make stave laminated Christmas ornaments. I run 6' strips through the planer, (first pass cuts one angle, second doubles the angle) then cut them to length. I use two slots in a piece of UHMW for my taper insert, but you will probably have to send the sled and piece through together.
Angles
John,
Go to the BP Articles section and download the Polygon freeware
http://www.woodcentral.com/bparticles/bpindex2.shtml#downloads
I've used it a number of times. You will be well served to do a mock-up first in junk wood. Easier to spot and solve problems when you don't have the "success-pressure" sitting on your shoulder whispering in your ear.
Ken Vaughan
Perfect even??
Ken Vaughan
I make buckets with loose staves and learned that they work fine if close but not perfect. In fact, it is almost impossible to get them even, so I do not even try after rough cutting on the bandsaw. I sometimes glue pairs to help avoid so many joints when working with "good wood".
If you jig and make your stave glueups in pairs and pairs of pairs, you will have a much easier glueup. True the halfs and move ahead. Same technique as standard segmented rings -but bigger.
The pairs approach will have creep from the glue joints and will not be perfect. It will be close, but not perfect.
On the other hand, it is easy to make extra pairs and pick the best ones (bucket trick of having a few extra staves
Re: Angles
I have the Woodworkers guide to compound angles and it has a chart for the proper angles. I will definitly make a mock up as well as cut some full size samples to get it right.
I thought about the planer, will look at that
Don't Forget
The "bird's mouth" joint technique for making columns. That way you make one taper cut and one angled dado cut on each stave
Use biscuits
Joe Flemig
John, For somrthing that big, I would use biscuit joinery between the staves. I know the segmented guys might scoff at this :-) but it will make construction a lot easier. Joe Fleming
Dick Hines
Re: Use biscuits
Dick Hines
You had better do it quick before NATO is in charge of who owns guns.
Mike Stafford
Mike Stafford
John, when I want to avoid the glue squeeze out on the interior I align the pieces with small pieces of tape on the top and bottom of the staves on the outside. Then I carefully flip the construct over and apply tape to the joints running from top to bottom of the staves. Then I flip the whole thing over, peel off the small bits of tape and carefully open the joints between the staves and apply my glue. Sort of the other way around in reverse way of doing it. You have to work quickly and it helps to have a helper when you form the circle and it is a bit easier if you have a way to use rubber bands to temporarily hold it in place while you are using your stretch tape to do the main job of clamping.
It helps to use the slower setting Titebond.
P.S. I almost forgot, if you have some turned "hoops" that are sized correctly to fit near the top and bottom ends of the construct they can help hold things tightly in place like the hoops on a barrel stave. Just remember to heavily wax the hoops or you will be turning them off later. I have on occasion sawed them out of plywood when I was in a hurry and they worked great.
Re: Use biscuits
I thought about biscuits and splines but actually think it will make it harder. Maybe not if I only glue 2 together at a time but I think I can glue 5 or 10 at once using the tape method. Since it will be long grain joints I don't think I will need any extra strength. It will also be held together at the bottom and top with screws into either the base plate or a top inner ring.
Re: Don't Forget
Mark I thought before I get serious about the construction I would look at birds mouth and even the rounded canoe bits.
Bird's Mouth
gives you a solid, 90° straight line glue joint on the outside. You've less potential for grain tear-out if/when you turn it circular.
This will give a new meaning to light arms .
Galen Vetterick
:D
the miniature version would be Small Arms
And Safe Arms would be a......
JamieDonaldson
..nice steel gun safe with a gooseneck lamp on top, eliminating many of the construction problems! :D
