Air brush pressure
Air brush pressure
Air brush pressure
What pressure do you all use for your air brush. I picked up an Iwata compressor that was on sale and it only goes to 18PSI. I had been using more than that for my older Paache. I don't have enough experience with my new Iwata air brush yet. It was spitting when I used 30PSI which is I think what I used on the Paache but I would have to fire it up and see.
Re: Air brush pressure
Hal Taylor
John, I just looked. I'm using a regulator off my big pump and it's set to about 22 lbs.
Rob Wallace
Re: Air brush pressure *LINK*
Rob Wallace
I have a dual action Paasche airbrush and I run it between 20 and 25 psi (almost always at 20 psi).....I've never used an Iwata airbrush, but if I remember what Binh Pho said during his demo (he uses Iwata airbrushes), the pressures that can be used are generally comparable among the various brands. The Iwata web site indicates 15 to 20 psi..... ...sounds like the pump should work OK.
Rob
Iwata Air Brush Web Site
Re: Air brush pressure/ your compressor should be
Joe Meirhaeghe
John, I have a Iwata compressor too and the air pressure is adjustable. either check out the users manual or go to the Iwata web site & look up the user manual. It will show you how to adjust the air pressure.
I use a Iwata dual action air brush & run any where from around 20 to 28 psi. depending on the paint & application I'm using.
Lan Brady
John,
When using Createx airbrush paints, I use 15-20 psi.
When using inks, I run 10-15 psi.
Folkart paint, I use 20-25 psi.
Not tried anything else.
Good Luck, Lan
Thanks Everyone. I'll try to pull out the airbrush tomorrow and play with it. I have to finish a video I'm doing for an article with Keith Thompkins and then I'm going to do a 30 mile bicycle ride. Got to keep up with the Tour De France guys.
Re: Bikers
There'll be no 'performance enhancing substances' where someone can find'em, right John? :|
Ride safe, please.
steve worcester
10-50PSI based on the line you want to pull and the fluid viscosity (and needle/tip size)
Glad to hear you are not slowing in retirement
I use Doughnuts
30-Mile Sugar Rush?
Gnarly, Dude!! :D :D
