MISTAKES - and how you deal with them . . .
charlie belden
. . . is one of the differences between a more experienced woodworkerand a new woodworker.
If you see mistakes as an opportunity to come up with a crreative fix, they're less annoying.
I'm doing another ball with finial and icicle on a pedestal miniature. The ball, finial and pedestal were done, and the icicle as about a minute from being done. I'd sharpened the bench chisel I was using, just for the last part of the icicle turning - a small ball on the tip. Guess that freshly sharpened edge cut a little deeper and faster than I'd intended, parting off the icicle - without the ball on top.
Faced with spending another half hour turning another one, I thought about other fixes. A little turquoise bead with a hole in it - and a small straight pin might do it. Cut the tip off the "good one" and pin a bead on the top of the finial and bottom of the icicle so they're look about the same. I had the little beads, but of course, no straight pins.
So off the the frabric store for two small straight pins. Naturally, they don't sell straight pins in pairs. But I did find some with small white tear drop shaped plastic tipped straight pins that would work great - similar color as the wood and the perfect small size. No surprise, they were the most expensive straight pins they had - $6.75 - for 200 of them. Now I just need to make a small hole for them to go in - after shortening them.
Will probably drill a small hole in my finger while drilling the holes in the parts - but skin is self healing.
Got a creative fix for one of your mistakes? Care to share the story - and maybe a picture or two?
Re: MISTAKES - and how you deal with them . . .
Dan Jechura
dan jechura
If your are delt lemons you make lemonade. Or in my case a bowl into a candle holder. Spalted Apple 8 inch by 1 1/2 high.
comments welcome
Dan j.
Dan Jechura
dan jechura
another apple bowl made into a candle holder. Same problem, turned thru the bottom. My daughter has it now. I think it was 6 inch by 3 inch.
Dan j.
charlie belden
Nice recovery - making an OOPS into a FEATURE - don't want those candles spilling wax on the furniture.
