what's the point?
what's the point?
what's the point?
GaryG in MD
I have a small (fist sized), cleaned, red malee burl that I was gifted by our friend Terry Scott. It's flat on the cut side (which is kind of dark and plain) and full of beautiful points on the rounded, light-colored side. I'm trying to decide what to make out of it and how to mount it.
I can keep the points natural as the outside bottom and just turn a shallow depression (bowl/platter) in the flat side. But then I have to figure out a way to make it sit on a table or be supported somehow. It's not inviting to be picked up that way because of the prickles.
Or I could make a small, real bowl out of it by turning off the points to reveal the birds-eye type character that underlie them. But, somehow, that seems like a waste.
Or I could do "something" (??) to keep the points and display them on the top side, like a pin cushion. Wouldn't even have to turn it to do that -- just flatten the bottom and display it as a natural object.
Or I could do the latter but do a little turning on the flat bottom to raise it off the table a bit. This might be more work than it's worth because of the need to build a chuck to hold the points without damage.
I've searched through many pages of WoW based on a search on the word "burl" and didn't really come up with anything that struck my fancy or spurred my imagination.
I've never had one of these before and don't want to "waste" it.
What should my goal be here?
The main question is whether to keep the points or turn them off.
What do you all feel is the "best" way to handle something like this?
TIA, Gary
Re: what's the point?
Don Lennon
You and I are in the same boat. I have many natural edged maple burls that have been pressure washed
and I want to do a shallow bowl in the cut side and maintain the "points" on the bottom after it is finished.
I have been unable to find a method so far.Any leads as how to do it would be greatly appreciated.
Don
Dan Jechura Temperance Mich.
I to bought a 14" by 10" by 5" burl with many points and a flat side. At this time it is sitting on a end table as a display item, because I do not know what to do with it. After I learn how to use my new bowl coring tool I hope to core out 2 bowls and leave the flat side and left over pins ( dog dish) as a 3rd bowl.
I also would like to here from other turners that have worked with "pin" burl's.
Dan J.
Steven Antonucci
Dunno, I break them all of the time
Steven Antonucci
Whenever I try to do something to preserve a natural burl , I end up breaking the pins and being annoyed by the fact that I broke some pins... and it is all that I ever see on the piece from that point forward.
Good luck, and have a Plan B.
S
Keeping the points
Scott Crumpton
I've never done this myself, only seen a video of it.
Build a hollow chuck/box/whatever on a faceplate that's big enough to set the burl in centered where you want to cut the bowel. Cover the burl with some plastic wrap, place it in the chuck and attach some wood strips over the front to hold it in. The burl should touch only the wood strips, not the sides or back of the chuck. Fill the void between the burl and the chuck with expanding polyurethane foam and allow it to set. You can now turn the bowel on the exposed face. To remove simply remove the wood retaining strips and pull it out of the foam.
Found the link, it was actually on this board a few days back.
http://www.youtube.com/watch?v=RX-kp-HZ5UQ&feature=channel&list=UL
Re: Keeping the points
Chuck Engstrom
Hi all -- a couple of weeks ago someone posted a link to this YouTube showing this box-of-foam idea in action:
http://www.youtube.com/watch?v=RX-kp-HZ5UQ&feature=relmfu
Gary, you may to have to slide the headstock down to the far end of the bed to make room for this apparatus but it oughta work OK if you build it carefully. Let us know how it works out.
Best to all -- Chuck near beautiful downtown Crumpton MD
There is an article...
GaryG in MD
in the latest American Woodturner (the John Jordan issue) on another method for doing it with vacuum, but it's pretty complicated. ...Gary
what I am trying to get at here...
GaryG in MD
...is not technique, but DESIGN.
Once I decide what I want the product to look like, I can work out the process.
The question is:
What is the (an) "ideal" end result for this little burl cap?
...Gary
john lopez
Terry Scott will probably have some good ideas on how to approach it.
I put pieces like that on a shelf and study them until the idea for the form occurs to me.
Sometimes it can take time.
I've mounted between centers & left bottom points alone except for a tenon & then a foot or base and then hollowed the inside.
Other times I've glued a waste block & faceplate then turned a tenon before hollowing the inside.
After finishing you can turn away the tenon and have a flat bottom
or a "calabash" style (rounded bottom) .
The dimensions of the blank often determine the method I use.
A sound fist-sized blank should be okay between centers if mounted carefully ...
and with good tool control you can avoid damage to desired features.
Remember to work out of the line of fire.
The important thing is to relax with it if it is something different for you &
have some general idea of what you want to end up with.
Tony Reynolds
Tony Reynolds
HI Gary,
Don't know how big your burl is but this is what I did with this Red Morrell burl. It's 16" by 12" by 3". I thought of save the natural side too but decided otherwise.
Tony
Back side
that's a real beauty, Tony...
GaryG in MD
Thanks for the inspiration. ...Gary
John,
GaryG in MD
It's just a burl cap, flat on one side.
I'm not sure there's enough there to hollow -- certainly not enough for a traditional HF.
I guess my real decision comes down to
1) pins down
2) pins up
3) pins to the side
4) no pins.
...Gary
Re: that's a real beauty, Tony...
Karen F.
I made a Brown Mallee natural edge platter and I turned a small foot on the back and left the wings with the spikes. I used some sand paper to "blunt" the spikes so it was easy to pick up without hurting yourself. I was looking for a picture but I can't find one and it has already been sold.
Thanks, Karen...
GaryG in MD
I appreciate the idea. Into the hopper it goes! ...Gary
Gary Gary Gary!!!!!
Terry Scott
Stop procrastinating and just turn the B thing :)
Mate I can offer you 333 different ways to attack it.
Seriously not that I am an expert but send me a picture of your burls Ill tell you what I can see being made out of them
If you are struggling that much just send me the burl
Here we go
No1 Hot melt glue it onto a backing board
Turn a single bowl
This was made 15 years ago my first attempt at keeping on mr prickle sat on three ugly acrylic feet
No2 As above but turn multiple overlapping bowls
No3 Why leave the prickles on the bottom ]
No4 Why worry were it sits let mother nature balance it
No5 Turn it inside out
No6 Make a tree farm
No7 Make a rocky Prickle
I could keep going with this all night Ive turned tonnes and tonnes of the stuff Love it with passion
Re: Gary Gary Gary!!!!!
john lopez
Gary ,
hollow was a poor choice of words on my part.
I should have said remove stock.
Anyway, I bet after seeing Terry's photos something will come to mind.
Have fun with it.
John
Lyle Jamieson
Re: John,
Lyle Jamieson
I like to do a shallow bowl. Start with the points up and the flat on the bottom. Make a football shape not a gord shape so the wings of the bowl are natural edge. Make it relatively thin and uniform wall thickness. The only spikes left will be in the edge of the rim of the bowl. You capture the best of both worlds with this design. You get the color and character of the burl in full view, yet you have the natural edge to celebrate the shape and destinct benefits of the burl. A plus for me is when the burl shape also creates natural voids in the side or bottom of the bowl.
I start between centers and use a laser to point at the probable natural edge of the bowl as I rotate the lathe by hand to get the right balance of high and low points of the finished bowl. Expect to move it between centers many times before you put it on the faceplate/glueblock. Take a little off, shaping the outside of the bowl first and watch the edge and shape developing slowly. Adjust the axis as you give yourself more information in the roughing stage.
Don Leydens
Thanks to Terry
Don Leydens
Gary, it's quite a coincidence, but I was up half the night thinking about what to do with a very similar burl problem. Terry's photos just jump started a bunch of ideas. Hope it did the same for you. Off to the shop I go!
It's about time!  ;-)
GaryG in MD
Hi Terry,
I hoped you would see this and jump in!
NOW I have some inspiration. Thanks, mate!
I would like to do "all the above", but I only have one.
We'll see what happens.
Cheers, Gary
That's the point!  :-)
GaryG in MD
Have fun and show us when it's done! ...Gary
Thanks, Lyle...
GaryG in MD
These are very good tips.
I'd never heard about using a laser like that.
Makes a lot of sense. Gotta give it a try.
I'm glad you reminded me about using a glue block too.
...Gary
Re: It's about time!  ;-)
Terry Scott
Come down here mate and you can have a go at turning them all
Don Leydens
Don Leydens
Hi Gary! Hope you got a chance to attack your burl. Finished mine yesterday and will post a photo when the finish is done. Terry's photos really got me going. Think I'll go hunt for some more burls!!
Charlie Anderson
Maybe I need to spend an extra day in NZ to visit you Terry.
Hope you had fun in San Jose!
