REAL MILK PAINT
Skill building
Skill building
Skill building
ONe thing not mentioned in Charlies minatures is the skill building that this develops. When you can cut a cove or bead or crisp V detail in a miniature it teaches you an awful lot about tool control. This makes it much easier to turn really crisp details in larger pieces. (Larger being relative since some details in my Christmas ornaments may be 3/32" or so)
The same is true for getting the form correct. It takes very good tool handling control to really nail a form correctly when the piece is 1/4" in diameter. This carries over to larger work very effectively. I have no trouble at all taking off a few thousandths of an inch to fine tune the shape of a box now that I've made pieces that only .025" tall.
You don't have to go that small of course. Try making doll house scale pieces. An 8" candlestick would be approx. 3/4" tall and have some really fine details to turn that will do wonders for your skill building.
You also don't need really small tools. My friend Jim Greenwood often does doll house scale pieces with a 3/8" bowl gouge. It's all about the cutting edge, being on the bevel and very light tool tool control. I should mention that you won't be on the bevel cutting a 1/8" cove with a 3/8" bowl gouge. That has to be a scraping cut but you can get buy with it on this scale if your delicate enough.
Re: Skill building
Alan Zenreich
Re: Skill building
Alan Zenreich
you made a turning .025" tall? Gee that's small... really small... really really small. Or maybe the decimal point got nudged a little during sanding
Re: Skill building
Re: Skill building
Don in Central Illinois
No Allen, it is that small. You need a magnifying glass to see it.
Re: Skill building
Steven Antonucci
Turned under a microscope if I recall?
Re: Skill building
My smallest goblet is actually .023" tall
Re: Skill building
I've had a splinter in my finger that big!
Re: Skill building
Re: Skill building
charlie belden
Actually, most of the cuts done on a miniature piece require only your hands to turn. When you scale up to regular sized pieces - for long blending of curves - your whole body needs to be moving correctly as well.
A rolling cut on something that's 1/8" diameter is different from what you'd do if it were at two or three inches in diameter.
But you're right that learning tool control at miniature scale does teach you tool control.
